Umbrel v0.3.13 is out with latest apps [security update]
Umbrel v0.3.13 is out with latest apps — Ride The Lightning, Specter, ThunderHub and LNbits in the Umbrel App Store, along with performance improvements. :rocket:
:rotating_light: The latest version of Ride The Lightning includes an important security fix and we recommend updating quickly!
If we don’t install RTL…can I wait to upgrade?
My current version is stable and I would rather wait.
Installed with no problems. Thank you!
Бърза инсталация, работи стабилно! Thanks!
Yes, you’re totally cool with not updating if you’ve not installed RTL.
My interface won’t let me log in since I did the upgraded. My node id is 03736617ddad36729149 if someone could check that is online at least.
@Ridge_Runner Can you access the interface using a smart phone? and can you SSH in?
I could not. I ended up figuring out that the ip address had changed during the latest update.
