[Update: Umbrel v0.3.12 was just released which fixes a bug in v0.3.11 that made Umbrel inaccessible over Tor]
Umbrel v0.3.11 is out with the latest versions of Specter Desktop, ThunderHub, Sphinx Relay, Ride The Lightning, and LNbits in the Umbrel App Store, hardware failure detection, low RAM alerts, and stability improvements. Just login to your Umbrel to update!
Until now if there was ever an issue with your hardware, your Umbrel would simply become inaccessible in a web browser. With this new update, you’ll now get clear actionable insights if something goes wrong, like this:
For those of you using Sphinx on iOS - you may have to delete the app, re-install and restore if you have any issues after the relay update. It is being worked on so just in case…
Hi I just updated to v0.3.13 without issue, I then followed the procedure to rename my node alias which I do after each update. I’m pretty sure I did it correctly but maybe not as now my node will not fully boot. It just sits there saying ‘Starting Umbrel’ Is this a matter of start from scratch and restore? or is there a workaround?
Edit: I can still SSH into my Umbrel, it looks like somehow I wiped the lnd.conf file as it’s now just blank. I don’t have a copy so I assume reinstall from scratch?
@Reach Thank you for the link, much appreciated. I don’t know what happened but I came back to try this today only to find my node booted up and working fine The lnd.conf file is fine and has the alias I added just before it appeared to have been broken.
Maybe I did it too quickly after the update and there was still something happening in the background or something like that? Either way I’m back up and running. But this has made me want to get a better grip on recovery incase my node does fall over. Thanks again for the reply
