Hello there,
First off; a big thanks for making Umbrel! It makes it possible for me to easily set up a node and run it to do my tiny bit for Bitcoin.
Secondly, I ran in to an issue which I can’t seem to resolve myself.
Device: Raspberry Pi 4 Model B Rev 1.4
Connection: Ethernet
Drive type: SSD
Fixed IP address configured in the node.
When V 0.3.11 was introduced, I was prompted on the dashboard to install it. I clicked to update, and it seemed to update just fine, but the update prompt was still visible on the dashboard. So I clicked it again, and the update process started again. , but the version number was V 0.3.10(!?) This time, a new message appeared on the settings page of the dashboard: “Last backup failed date+time”.
So, I set out to update my node manually. I used your FAQ instructions and followed it to the letter (changing the version number to v0.3.12). It asked me for my PW I hit enter, and it started making a clone. After that I got a lot of failures and the update failed. Check it out below what happened ![]()
umbrel@umbrel:~/umbrel $ cd ~/umbrel && sudo rm -f statuses/update-in-progress && sudo ./scripts/update/update --repo getumbrel/umbrel#v0.3.12
[sudo] password for umbrel:
Cloning into ‘/tmp/umbrel-update’…
fatal: unable to access ‘GitHub - getumbrel/umbrel: A beautiful home server OS for self-hosting with an app store. Buy a pre-built Umbrel Home with umbrelOS, or install on a Raspberry Pi 4, any Ubuntu/Debian system, or a VPS.’: Could not resolve host: github.com
fatal: not a git repository: ‘/tmp/umbrel-update//.git’
mv: cannot stat ‘/tmp/umbrel-update//info.json’: No such file or directory
jq: error: Could not open file /tmp/umbrel-update//info.json.orig: No such file or directory
Update path doesn’t seem to be an Umbrel install.
I have no idea what went wrong or how to fix it. Any input / help is greatly welcomed!
Thanks in advance,
Mooky
But the issue persists.
