Hello everyone,
Update Umbrel on Raspberrypi OS from v0.5.4 to v0.5.4-patch-1 fails in several times.
sudo ./scripts/update/update --repo getumbrel/umbrel#0.5.4-patch-1
fails with
Clone to ‘/tmp/umbrel-update’ …
warning: Could not find remote branch v0.5.4-patch-1 to clone.
fatal: Remote-Branch v0.5.4-patch-1 not found in upstream repository origin
fatal: No Git repository: ‘/tmp/umbrel-update//.git’
mv: the call of stat for ‘/tmp/umbrel-update//info.json’ is not possible: File or directory not found
jq: error: Could not open file /tmp/umbrel-update//info.json.orig: No such file or directory
Update path doesn’t seem to be an Umbrel install.
and
echo ‘{“state”: “success”, “progress”: 100, “description”: “Successfully installed Umbrel v0.5.4”, “updateTo”: “v0.5.4-patch-1”}’ | sudo tee statuses/update-status.json && sudo scripts/update/update --ota
fails with
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Running update install scripts of the new release
scripts/update/update: line 136: cd: scripts/update: file or directory not found
ls: Unable to access ‘*-run.sh’: File or directory not found
Deleting cloned repository
Removing lock
Stopped scripts and containers before update-command.
Is there another way to try to update?
Thank you very much!
