Cannot update from version 0.5.4 to 1.0 (install Umbrel 1.0 on SD card?)
Hi, I am trying to update my Umbrel from version 0.5.4 to 1.0. It give me the option to update but after a few seconds I get an error message (I get a brief message saying something like install Umbrel 1.0 on SD card??).
Any help is much appreciated!
This update you manually need to put the files from the website on your pc to the sd card of the pi.
@Merlin Thank you for your answer. I have a bitcoin machine (plug and play). Do you know where I can find the information to do this manually?
