Okrusch
February 24, 2022, 2:54pm
1
Hi, I’m trying to set up my node with a Raspberry Pi 4 with 8gb Ram.
When trying to access umbrel.local I get the error message “System service failed”. So I tried running the debug script via ssh. I connect via ssh with my Mac without any trouble. after running “~/umbrel/scripts/debug” there is no output on my terminal. I also tried “~/umbrel/scripts/debug --update” or connecting with “ssh -t umbrel@umbrel.local”. Still no output.
Im guessing that some settings on my Mac are wrong.
Thanks for your help.
Run without “–update”.
Save the log into a file.
here is a guide
There are a variety of logs that provide useful information on your Umbrel machine. In every case, we need you to copy the log entries and input them into an online service like 0bin (set the expiration to 1 month) or pastebin.com , which will provide a link that you can share.
If you are able to log into Umbrel through a browser
Logs are available under Settings->Troubleshooting. Please note that it may take a moment to output all the logs.
[image]
[image]
If you are unable to log into Umbr…
Okrusch
February 24, 2022, 3:02pm
3
I followed that guid already. The session file also did not have any output.
It is very clear that guide
You should get a response with the log, whatever will be the errors or not.
Okrusch
February 24, 2022, 3:25pm
5
Here we go. can’t find the file, although its clearly there.
Okrusch
February 24, 2022, 3:31pm
6
If I try this command: ssh -t umbrel@umbrel.local “tail -n200 ~/umbrel/logs/karen.log”
I get tail command not found.
You are doing it wrong.
login with SSH
then
cd umbrel
./scripts/debug
Done, you will get the full logs
Okrusch
February 24, 2022, 5:33pm
8
Still nothing. After pressing enter I just get a new line.
Okrusch
February 24, 2022, 5:49pm
9
I fixed my issue. Formated the SSD. I can now access the umbrel setup screen.
Okrusch
February 24, 2022, 5:50pm
10
Debugging also works now.
