Umbrel Error: System service failed
Went to long in and got the. Error: System service failed
here is the ~/umbrel/scripts/debug
I am not the best with ssh. using terminal on a Mac. will need help navigating.
0.4.8
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision : c03114
Serial : 10000000f6ce892c
Firmware
Oct 29 2021 10:47:33
Copyright © 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=39.9’C
Throttling
throttled=0x0
Mem: 3.8G 124M 3.5G 8.0M 209M 3.6G
Swap: 0B 0B 0B
total: 3.3%
system: 3.3%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 30G 3.1G 25G 11% /
Startup service logs
– Logs begin at Fri 2021-11-26 17:36:03 UTC, end at Fri 2021-11-26 17:41:12 UTC. –
Nov 26 17:36:11 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 26 17:36:11 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Nov 26 17:36:08 umbrel systemd[1]: Starting External Storage Mounter…
Nov 26 17:36:08 umbrel external storage mounter[479]: Running external storage mount script…
Nov 26 17:36:08 umbrel external storage mounter[479]: Found device “CT1000MX 500SSD1”
Nov 26 17:36:08 umbrel external storage mounter[479]: Blacklisting USB device IDs against UAS driver…
Nov 26 17:36:08 umbrel external storage mounter[479]: Rebinding USB drivers…
Nov 26 17:36:08 umbrel external storage mounter[479]: Checking USB devices are back…
Nov 26 17:36:08 umbrel external storage mounter[479]: Waiting for USB devices…
Nov 26 17:36:09 umbrel external storage mounter[479]: Waiting for USB devices…
Nov 26 17:36:10 umbrel external storage mounter[479]: Checking if the device is ext4…
Nov 26 17:36:11 umbrel external storage mounter[479]: Yes, it is ext4
Nov 26 17:36:11 umbrel external storage mounter[479]: mount: /mnt/data: can’t read superblock on /dev/sda1.
Nov 26 17:36:11 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=32/n/a
Nov 26 17:36:11 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Nov 26 17:36:11 umbrel systemd[1]: Failed to start External Storage Mounter.
Nov 26 17:36:11 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 26 17:36:11 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
services.tor.ports contains an invalid type, it should be a number, or an object
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
It’s your drive. Start to understand how to read your own logs. Are very clear.
So check your drive. You had data corruption due to hardware failure.
