Please Help! System Service Failed?
Last week I went to log into my umbrel node and got this message: System Service Failed. It was the first time I’d seen it. After some research and restarting my node several times, I thought maybe it was the ssd card. So I re-flashed it with the latest update and started up my node again. Now when I sign in with ssh umbrel@umbrel.local I get this?
Can someone help me fix my node so I can sign in again?
0.4.11
Flashed OS version
v0.4.11
Raspberry Pi Model
Revision : d03114
Serial : 10000000cabce193
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=41.8’C
Throttling
throttled=0x0
Mem: 7.8G 127M 7.5G 8.0M 224M 7.6G
Swap: 0B 0B 0B
total: 1.6%
system: 1.6%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
tail: cannot open ‘/home/umbrel/umbrel/scripts/../logs/memory-monitor.log’ for reading: No such file or directory
/dev/root 30G 3.2G 25G 12% /
Startup service logs
– Logs begin at Wed 2022-01-26 23:27:26 UTC, end at Thu 2022-01-27 00:21:05 UTC. –
Jan 26 23:27:45 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Jan 26 23:27:45 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Jan 26 23:27:30 umbrel systemd[1]: Starting External Storage Mounter…
Jan 26 23:27:30 umbrel external storage mounter[488]: Running external storage mount script…
Jan 26 23:27:30 umbrel external storage mounter[488]: No block devices found
Jan 26 23:27:30 umbrel external storage mounter[488]: Waiting for 5 seconds before checking again…
Jan 26 23:27:35 umbrel external storage mounter[488]: Found device “SanDisk Extreme 55AE”
Jan 26 23:27:35 umbrel external storage mounter[488]: Blacklisting USB device IDs against UAS driver…
Jan 26 23:27:36 umbrel external storage mounter[488]: Rebinding USB drivers…
Jan 26 23:27:36 umbrel external storage mounter[488]: Checking USB devices are back…
Jan 26 23:27:36 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:37 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:38 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:39 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:40 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:41 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:42 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:43 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:44 umbrel external storage mounter[488]: Waiting for USB devices…
Jan 26 23:27:45 umbrel external storage mounter[488]: Checking if the device is ext4…
Jan 26 23:27:45 umbrel external storage mounter[488]: No, it’s not ext4
Jan 26 23:27:45 umbrel external storage mounter[488]: Formatting device…
Jan 26 23:27:45 umbrel external storage mounter[488]: wipefs: error: /dev/sda: probing initialization failed: No medium found
Jan 26 23:27:45 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Jan 26 23:27:45 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Jan 26 23:27:45 umbrel systemd[1]: Failed to start External Storage Mounter.
Jan 26 23:27:45 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Jan 26 23:27:45 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
umbrel@umbrel:~ $ Connection to umbrel.local closed by remote host.
Problem seems to be in the external storage (SSD, usb cable or adapter). Try to open it with a file manager in a linux system (raspberian is ok).
The best test to external storage is to do copy of large files and check the copy speed from the disc to itself, For a SSD disc with usb3 adapter the speed should be more than 100MB/s.
I’m a total noob when it comes to this. How do I test my hard drive? Do i just download rasberian on my laptop, then plug in SSD?
Side note:
When I plug SSD into my laptop the computer recognizes it as a device but wont let me open an transfer files. Is that normal?
Windows won’t recognize ext4 files system, used in Umbrel.
Raspberian is a linux system used by RPi, you have to flash it to another SD card, plug a mouse, keyboard and monitor to RPi to run it. Then you can enable VNC to remote access the RPi using your laptop
To check your SSD disk health, install Crystal Disk Info to your PC. If it don´t give a high note (with blue color) to it, then maybe SSD has broken.
But is very common usb cable and case board broken, too. So change this parts and do again tests to the SSD disc before discard it.
