Umbrel on Pi4 dead - I'm lost
Hi! All of a sudden things stopped to work.
I’m not sure if the Hard Drive is the issue or something else. Can’t get Umbrel to start.
Please help! Any step-by-step advice? How can I access my funds/wallet?
Using a Pi4 with Umbrel. Worked normally until today.
Was it really a HDD or SSD?
Can you be more specific regarding what problems you are experiencing? For starters: Are you able to communicate with your node? What happens if you write http://umbrel.local/ in the address bar of your browser? Is your SSD still a 1TB?
Like any computer, there are basic steps to troubleshoot. Are there lights on the machine? A common event for a Pi is for the SD card to go bad.
I got it solved. The power plug delivering power to the Pi and SDD is faulty. I replaced it with a different one and now the SDD doesn’t get cut off anymore.
