Hi folks, is there a vision to be able to run Umbrel on a phone (rather than a Pi or a laptop)?
Why or why not? Thanks
You can access your umbrel on a phone via umbrel.local or tailscale, but i don’t think umbrel will be able to boot on a phone, atleast for the near future. Not a dev though.
Hi @Pinotio.com! You can run Umbrel on any device based on Ubuntu/Debian. Unfortunately, you can’t run Umbrel on a phone, but you can access and manage your Umbrel directly from your phone at http://umbrel.local
In idea it will. Just try it
There is already a guy in brazil, that made a bitcoin node work on a samsung phone using TERMUX
This is more a proof of concept, but a good starting point.
Problems
You need to have a phone with SD Card ot external Drive or 1TB Memory.
Be aware of Data usage (only wifi)
Another interesting approach would be to use a google Phone like the Pixel7 which allows to setup KVM where you can start Docker Containers. See link below
Sources:
https://www.reddit.com/r/Android/comments/ybq4ih/pixel_7_has_kvm_on_by_default_and_i_finally_got_a/
