Umbrel not showing "umbrel is now available at 192.168.xx" and can't acess
For some reason, it dont show anymore the message that aware me that i can acess through my ip…
here are a few options to try. My node is down right now but these work in other linux distros.
hostname -I
ifconfig
ip a
any one of those should give you what youre looking for.
you can also find it in your router or you can download a network scanner on your phone “fing’“ used to be a good one for android. It used to be free I havent used it in awhile so im not sure about now.
Also make sure it is connected by an ethernet connection as otherwise you won’t get an IP.
