Hi friends, I have been running umbrel for a while with the previous software before 0.5.0. It used to run fine until I updated to the 0.5.0 software.
All I know is that I could not access interface. Now after reflashing a few times my umbrel is not starting at all. Also I assigned umbrel fixed ip to router but no results unfortunately.
I dont know what else can I do, I have my seedphrase but unfortunately I had not done a backup of my lightning channels. Any suggestions appreciated please. Also the debug log has been pasted, Thanks guys!
0.5.0
Flashed OS version
v0.5.0
Raspberry Pi Model
Revision        : c03111
Serial          : 10000000cacbc36b
Model           : Raspberry Pi 4 Model B Rev 1.1
Firmware
Dec  1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=47.7’C
Throttling
throttled=0x0
Mem:           3.8G        148M        3.4G        8.0M        281M        3.6G
Swap:          4.1G          0B        4.1G
total: 3.9%
system: 3.9%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root        29G  3.0G   25G  11% /
/dev/sda1       916G  4.1G  866G   1% /home/umbrel/umbrel
Startup service logs
Jun 07 16:07:26 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jun 07 16:07:26 umbrel systemd[1]: Starting Umbrel Startup Service…
Jun 07 16:07:26 umbrel umbrel startup[8530]: ======================================
Jun 07 16:07:26 umbrel umbrel startup[8530]: ============ CONFIGURING =============
Jun 07 16:07:26 umbrel umbrel startup[8530]: ========= UMBREL (mainnet) ===========
Jun 07 16:07:26 umbrel umbrel startup[8530]: Generating auth credentials
Jun 07 16:07:26 umbrel umbrel startup[8530]: Generating Tor password
Jun 07 16:07:26 umbrel umbrel startup[8530]: Unable to find image ‘getumbrel/tor:v0.4.1.9’ locally
Jun 07 16:07:36 umbrel umbrel startup[8530]: docker: Error response from daemon: Get “https://registry-1.docker.io/v2/”: dial tcp: lookup registry-1.docker.io on 192.168.1.109:53: read udp 192.168.1.100:46655->192.168.1.109:53: i/o timeout.
Jun 07 16:07:36 umbrel umbrel startup[8530]: See ‘docker run --help’.
Jun 07 16:07:36 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=125/n/a
Jun 07 16:07:36 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 07 16:07:36 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jun 07 16:07:46 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jun 07 16:07:46 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 148.
Jun 07 16:07:46 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jun 07 16:07:46 umbrel systemd[1]: Starting Umbrel Startup Service…
Jun 07 16:07:46 umbrel umbrel startup[8727]: ======================================
Jun 07 16:07:46 umbrel umbrel startup[8727]: ============ CONFIGURING =============
Jun 07 16:07:46 umbrel umbrel startup[8727]: ========= UMBREL (mainnet) ===========
Jun 07 16:07:46 umbrel umbrel startup[8727]: Generating auth credentials
Jun 07 16:07:46 umbrel umbrel startup[8727]: Generating Tor password
Jun 07 16:07:47 umbrel umbrel startup[8727]: Unable to find image ‘getumbrel/tor:v0.4.1.9’ locally
Jun 07 16:07:57 umbrel umbrel startup[8727]: docker: Error response from daemon: Get “https://registry-1.docker.io/v2/”: dial tcp: lookup registry-1.docker.io on 192.168.1.109:53: read udp 192.168.1.100:39717->192.168.1.109:53: i/o timeout.
Jun 07 16:07:57 umbrel umbrel startup[8727]: See ‘docker run --help’.
Jun 07 16:07:57 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=125/n/a
Jun 07 16:07:57 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 07 16:07:57 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Tue 2022-06-07 15:16:31 UTC, end at Tue 2022-06-07 16:08:03 UTC. –
Jun 07 15:16:37 umbrel systemd[1]: Starting External Storage Mounter…
Jun 07 15:16:37 umbrel external storage mounter[506]: Running external storage mount script…
Jun 07 15:16:39 umbrel external storage mounter[506]: Found device “SanDisk SSD PLUS 1000GB”
Jun 07 15:16:39 umbrel external storage mounter[506]: Blacklisting USB device IDs against UAS driver…
Jun 07 15:16:39 umbrel external storage mounter[506]: Rebinding USB drivers…
Jun 07 15:16:40 umbrel external storage mounter[506]: Checking USB devices are back…
Jun 07 15:16:40 umbrel external storage mounter[506]: Waiting for USB devices…
Jun 07 15:16:41 umbrel external storage mounter[506]: Waiting for USB devices…
Jun 07 15:16:42 umbrel external storage mounter[506]: Checking if the device is ext4…
Jun 07 15:16:42 umbrel external storage mounter[506]: Yes, it is ext4
Jun 07 15:16:42 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
Jun 07 15:16:42 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
Jun 07 15:16:42 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
Jun 07 15:16:42 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
Jun 07 15:16:42 umbrel external storage mounter[506]: Bind mounting external storage to /swap
Jun 07 15:16:42 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
Jun 07 15:16:42 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
Jun 07 15:16:44 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
Jun 07 15:16:44 umbrel external storage mounter[506]: Checking /swap is now on external storage…
Jun 07 15:16:44 umbrel external storage mounter[506]: Setting up swapfile
Jun 07 15:16:44 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 07 15:16:44 umbrel external storage mounter[506]: no label, UUID=278be917-6659-4a84-81c6-e1ea92ac11f7
Jun 07 15:16:45 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
Jun 07 15:16:45 umbrel external storage mounter[506]: Starting external drive mount monitor…
Jun 07 15:16:45 umbrel external storage mounter[506]: Mount script completed successfully!
Jun 07 15:16:45 umbrel systemd[1]: Started External Storage Mounter.
Jun 07 15:16:52 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jun 07 15:16:52 umbrel external storage updater[961]: Checking if SD card Umbrel is newer than external storage…
Jun 07 15:16:52 umbrel external storage updater[961]: No, SD version is not newer, exiting.
Jun 07 15:16:52 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor logs
==== Result ====
