Issues connected to Umbrel (can only ssh in)
My umbrel was working fine for months. Then I moved to a new home and cannot get it connected. I can’t even get to the welcome screen now to enter my password (can’t connect).
I am able to ssh in and pulled this info… ANY IDEAS/SUGGESTIONS?
Jun 5 15:05:14 umbrel dockerd[659]: time=“2021-06-05T15:05:14.749824877Z” level=warning msg=“Error getting v2 registry: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”
Jun 5 15:05:14 umbrel dockerd[659]: time=“2021-06-05T15:05:14.749996043Z” level=info msg=“Attempting next endpoint for pull after error: Get registry request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”
Jun 5 15:05:14 umbrel dockerd[659]: time=“2021-06-05T15:05:14.750268266Z” level=error msg=“Handler for POST /v1.40/images/create returned error: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”
Jun 5 15:05:14 umbrel umbrel startup[5293]: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)
Jun 5 15:05:14 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jun 5 15:05:14 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 5 15:05:14 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jun 5 15:05:25 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jun 5 15:05:25 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 21.
Jun 5 15:05:25 umbrel systemd[1]: Stopped Umbrel Startup Service.
Can you try to reflash the microSD card with the latest version?
If I re-flash will I lose my funds?
I re-flashed and now I’m stuck on the “starting umbrel” screen. Any thoughts?
I tried to ssh in and this is the message I get:
@ WARNING: POSSIBLE DNS SPOOFING DETECTED! @
The ECDSA host key for umbrel.local has changed,
and the key for the corresponding IP address xxxxxxxxxxxxxxxxxxxx
is unknown. This could either mean that
DNS SPOOFING is happening or the IP address for the host
and its host key have changed at the same time.
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:xxxxxxxxxxxxxxxxxxxxxxxxx.
Please contact your system administrator.
Add correct host key in C:\Users\xxxx/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in C:\Users\xxxx/.ssh/known_hosts:1
ECDSA host key for umbrel.local has changed and you have requested strict checking.
Host key verification failed.
Delete the file C:\Users\xxxx/.ssh/known_hosts on your computer and try again.
Can you get the logs please? Once you could login into the Pi, execute this command, paste the output to a service like pastebin.com and send me the
0.3.10
Umbrel OS version
v0.3.14
Raspberry Pi Model
Revision : c03112
Serial : 100000006dc317ca
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
May 27 2021 14:02:15
Copyright © 2012 Broadcom
Temperature
temp=45.2’C
Throttling
throttled=0x0
Mem: 3.8G 159M 2.6G 142M 1.1G 3.4G
Swap: 4.1G 0B 4.1G
total: 4.2%
system: 4.2%
tor: 0%
thunderhub: 0%
sphinx-relay: 0%
specter-desktop: 0%
samourai-server: 0%
ride-the-lightning: 0%
mempool: 0%
lnd: 0%
lightning-terminal: 0%
electrs: 0%
btc-rpc-explorer: 0%
bluewallet: 0%
bitcoin: 0%
/dev/root 59G 2.9G 53G 6% /
/dev/sda1 916G 485G 385G 56% /home/umbrel/umbrel
Startup service logs
Jun 30 01:37:39 umbrel umbrel startup[2329]: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The NGINX_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The NGINX_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The LND_REST_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The LND_GRPC_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The LND_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The MIDDLEWARE_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The NEUTRINO_SWITCHER_IP variable is not set. Defaulting to a blank string.Jun 30 01:37:39 umbrel umbrel startup[2329]: The ELECTRUM_PORT variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The ELECTRUM_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Jun 30 01:37:39 umbrel umbrel startup[2329]: The Compose file ‘./docker-compose.yml’ is invalid because:
Jun 30 01:37:39 umbrel umbrel startup[2329]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.tor.ports contains an invalid type, it should be a number, or an object
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.bitcoin.ports contains an invalid type, it should be a number, or an object
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.electrs.ports contains an invalid type, it should be a number, or an object
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.lnd.ports contains an invalid type, it should be a number, or an object
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.nginx.ports contains an invalid type, it should be a number, or an object
Jun 30 01:37:39 umbrel umbrel startup[2329]: services.lnd.ports value [‘9735:9735’, ‘:’, ‘:’] has non-unique elements
Jun 30 01:37:39 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jun 30 01:37:39 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 30 01:37:39 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Tue 2021-06-29 14:56:24 UTC, end at Wed 2021-06-30 01:37:39 UTC. –
Jun 29 14:56:32 umbrel systemd[1]: Starting External Storage Mounter…
Jun 29 14:56:32 umbrel external storage mounter[507]: Running external storage mount script…
Jun 29 14:56:37 umbrel external storage mounter[507]: Found device “SanDisk SSD PLUS 1000GB”
Jun 29 14:56:37 umbrel external storage mounter[507]: Blacklisting USB device IDs against UAS driver…
Jun 29 14:56:37 umbrel external storage mounter[507]: Rebinding USB drivers…
Jun 29 14:56:38 umbrel external storage mounter[507]: Checking USB devices are back…
Jun 29 14:56:38 umbrel external storage mounter[507]: Waiting for USB devices…
Jun 29 14:56:39 umbrel external storage mounter[507]: Waiting for USB devices…
Jun 29 14:56:40 umbrel external storage mounter[507]: Checking if the device is ext4…
Jun 29 14:56:40 umbrel external storage mounter[507]: Yes, it is ext4
Jun 29 14:56:44 umbrel external storage mounter[507]: Checking if device contains an Umbrel install…
Jun 29 14:56:44 umbrel external storage mounter[507]: Yes, it contains an Umbrel install
Jun 29 14:56:44 umbrel external storage mounter[507]: Bind mounting external storage over local Umbrel installation…
Jun 29 14:56:44 umbrel external storage mounter[507]: Bind mounting external storage over local Docker data dir…
Jun 29 14:56:44 umbrel external storage mounter[507]: Bind mounting external storage to /swap
Jun 29 14:56:44 umbrel external storage mounter[507]: Bind mounting SD card root at /sd-card…
Jun 29 14:56:44 umbrel external storage mounter[507]: Checking Umbrel root is now on external storage…
Jun 29 14:56:48 umbrel external storage mounter[507]: Checking /var/lib/docker is now on external storage…
Jun 29 14:56:48 umbrel external storage mounter[507]: Checking /swap is now on external storage…
Jun 29 14:56:48 umbrel external storage mounter[507]: Setting up swapfile
Jun 29 14:56:50 umbrel external storage mounter[507]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 29 14:56:50 umbrel external storage mounter[507]: no label, UUID=cbb94dcd-9a4a-44a9-a611-4ab5a99682e4
Jun 29 14:56:50 umbrel external storage mounter[507]: Checking SD Card root is bind mounted at /sd-root…
Jun 29 14:56:50 umbrel external storage mounter[507]: Starting external drive mount monitor…
Jun 29 14:56:50 umbrel external storage mounter[507]: Mount script completed successfully!
Jun 29 14:56:50 umbrel systemd[1]: Started External Storage Mounter.
Jun 29 14:57:36 umbrel external storage updater[1071]: Configuring new release
Jun 29 14:57:36 umbrel external storage updater[1071]: ======================================
Jun 29 14:57:36 umbrel external storage updater[1071]: =========== RECONFIGURING ============
Jun 29 14:57:36 umbrel external storage updater[1071]: ========= UMBREL (mainnet) ===========
Jun 29 14:57:36 umbrel external storage updater[1071]: Generating auth credentials
Jun 29 14:57:36 umbrel external storage updater[1071]: Generating Tor password
Jun 29 14:57:38 umbrel external storage updater[1071]: Unable to find image ‘getumbrel/tor:v0.4.1.9’ locally
Jun 29 14:57:48 umbrel external storage updater[1071]: docker: Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 8.8.8.8:53: read udp 169.254.97.165:53469->8.8.8.8:53: i/o timeout.
Jun 29 14:57:48 umbrel external storage updater[1071]: See ‘docker run --help’.
Jun 29 14:57:48 umbrel external storage updater[1071]: == End Update Script 01-run.sh ==
Jun 29 14:57:48 umbrel external storage updater[1071]: == Begin Update Script 02-run.sh ==
Jun 29 14:57:48 umbrel external storage updater[1071]: =======================================
Jun 29 14:57:48 umbrel external storage updater[1071]: =============== UPDATE ================
Jun 29 14:57:48 umbrel external storage updater[1071]: ========= Stage: Post-update ==========
Jun 29 14:57:48 umbrel external storage updater[1071]: == End Update Script 02-run.sh ==
Jun 29 14:57:48 umbrel external storage updater[1071]: == Begin Update Script 03-run.sh ==
Jun 29 14:57:48 umbrel external storage updater[1071]: =========== Stage: Success ============
Jun 29 14:57:48 umbrel external storage updater[1071]: Removing backup
Jun 29 14:57:48 umbrel external storage updater[1071]: Successfully installed Umbrel 0.3.14
Jun 29 14:57:48 umbrel external storage updater[1071]: == End Update Script 03-run.sh ==
Jun 29 14:57:48 umbrel external storage updater[1071]: Deleting cloned repository
Jun 29 14:57:48 umbrel external storage updater[1071]: Removing lock
Jun 29 14:57:48 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Bitcoin Core logs
LND logs
Tor logs
App logs
bluewallet
ERROR: Couldn’t find env file: /home/umbrel/umbrel/.env
btc-rpc-explorer
lightning-terminal
mempool
ride-the-lightning
samourai-server
specter-desktop
sphinx-relay
thunderhub
==== Result ====
Please copy the entire output of this script and paste it in the Umbrel Telegram group (https://t.me/getumbrel) so we can help you with your problem.
It’s recommended to upload the output somewhere and share a link to it. Run this script with ‘–upload’ to automatically generate a link to share.
umbrel@umbrel:~ $
Ok I did that. Tried again and still stuck on the “Starting Umbrel” screen.
I tried to ssh in again and once again my old password doesn’t work. Only “moneyprintergobrrr”.
Here are updated logs after deleting the “known_hosts” file and rebooting and trying againl.
Hi yes I had already done that and the error I had shared were pulled after I had re-flashed. Should I try again?
Hi again… I tried re-flashing twice and I still am stuck in teh same spot with the same error logs and the umbrel page stuck on “starting umbrel”. Any other ideas?
Phuuuck!
me too
@Honeybadger1 @LibertyBTC Hey guys, sorry for the long delay, I missed your responses. Could you get you issue sorted?
Hi thanks for replying
Unfortunately not. I reflashed and still get stuck on the starting umbrel screen with the same error logs
@Honeybadger1 DMd you.
Wait, why the DM? I am stuck on this issue and would like to see the fix for it.
same, havnt reflashed, but getting a similar issue where it will work but then after a few hours i can not connect to umbrel.local, and eventually it will connect in the browser and say Error: System service failed but running through logs after getting it login working (sporadically) nothing seems to have triggered a failure event…
any more insight as to what i should do. i have no funds or channels, just dont want to have to redownload the entire timechain again if possible. not sure if this worry is valid or not when reflashing, since its already downloaded on the hard drive from the first time i got umbrel set up
FIXED! The issue was my internet connection. I was using my wi fi from my apartment and I needed to plug my pi directly into the router. I had configured the ipv4 settings correctly, but for some reason the connection in my apartment (paid for by the manager) would not allow me to connect.
