No run umbrel and log no see error in rasberry pi4
0.5.0
Flashed OS version
v0.5.0
Raspberry Pi Model
Revision        : d03114
Serial          : 100000008752651f
Model           : Raspberry Pi 4 Model B Rev 1.4
Firmware
Dec  1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=31.1’C
Throttling
throttled=0x0
Mem:           7.8G        160M        7.0G         16M        604M        7.5G
Swap:          4.1G          0B        4.1G
total: 2.1%
system: 2.1%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root        59G  3.1G   53G   6% /
/dev/sda1       1.8T  4.2G  1.7T   1% /home/umbrel/umbrel
Startup service logs
Jul 15 01:24:36 umbrel umbrel startup[19841]: ============ CONFIGURING =============
Jul 15 01:24:36 umbrel umbrel startup[19841]: ========= UMBREL (mainnet) ===========
Jul 15 01:24:36 umbrel umbrel startup[19841]: ======================================
Jul 15 01:24:36 umbrel umbrel startup[19841]: Generating hidden services…
Jul 15 01:24:38 umbrel umbrel startup[19841]: stat /var/lib/docker/overlay2/3e2aa4fbff01be12ab902eb690518a77f158bc1e2e088fdc82dffdd3ff10d7f2: no such file or directory
Jul 15 01:24:38 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jul 15 01:24:38 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jul 15 01:24:38 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jul 15 01:24:48 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jul 15 01:24:48 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 91.
Jul 15 01:24:48 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jul 15 01:24:48 umbrel systemd[1]: Starting Umbrel Startup Service…
Jul 15 01:24:48 umbrel umbrel startup[20029]: ======================================
Jul 15 01:24:48 umbrel umbrel startup[20029]: ============ CONFIGURING =============
Jul 15 01:24:48 umbrel umbrel startup[20029]: ========= UMBREL (mainnet) ===========
Jul 15 01:24:48 umbrel umbrel startup[20029]: Generating hidden services…
Jul 15 01:24:50 umbrel umbrel startup[20029]: stat /var/lib/docker/overlay2/3e2aa4fbff01be12ab902eb690518a77f158bc1e2e088fdc82dffdd3ff10d7f2: no such file or directory
Jul 15 01:24:50 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jul 15 01:24:50 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jul 15 01:24:50 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jul 15 01:25:00 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jul 15 01:25:00 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 92.
Jul 15 01:25:00 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jul 15 01:25:00 umbrel systemd[1]: Starting Umbrel Startup Service…
Jul 15 01:25:00 umbrel umbrel startup[20217]: ======================================
Jul 15 01:25:00 umbrel umbrel startup[20217]: ============ CONFIGURING =============
Jul 15 01:25:00 umbrel umbrel startup[20217]: ========= UMBREL (mainnet) ===========
Jul 15 01:25:01 umbrel umbrel startup[20217]: Generating hidden services…
External storage service logs
– Logs begin at Tue 2022-06-07 15:16:31 UTC, end at Fri 2022-07-15 01:25:01 UTC. –
Jun 07 15:16:37 umbrel systemd[1]: Starting External Storage Mounter…
Jun 07 15:16:37 umbrel external storage mounter[506]: Running external storage mount script…
Jun 07 15:16:39 umbrel external storage mounter[506]: Found device “sage 3639S”
Jun 07 15:16:39 umbrel external storage mounter[506]: Blacklisting USB device IDs against UAS driver…
Jun 07 15:16:39 umbrel external storage mounter[506]: Rebinding USB drivers…
Jun 07 15:16:40 umbrel external storage mounter[506]: Checking USB devices are back…
Jun 07 15:16:40 umbrel external storage mounter[506]: Waiting for USB devices…
Jun 07 15:16:41 umbrel external storage mounter[506]: Waiting for USB devices…
Jun 07 15:16:42 umbrel external storage mounter[506]: Waiting for USB devices…
Jun 07 15:16:43 umbrel external storage mounter[506]: Checking if the device is ext4…
Jul 15 01:06:11 umbrel external storage mounter[506]: Yes, it is ext4
Jul 15 01:06:11 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
Jul 15 01:06:11 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
Jul 15 01:06:11 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
Jul 15 01:06:11 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
Jul 15 01:06:11 umbrel external storage mounter[506]: Bind mounting external storage to /swap
Jul 15 01:06:11 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
Jul 15 01:06:11 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
Jul 15 01:06:12 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
Jul 15 01:06:12 umbrel external storage mounter[506]: Checking /swap is now on external storage…
Jul 15 01:06:12 umbrel external storage mounter[506]: Setting up swapfile
Jul 15 01:06:12 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 15 01:06:12 umbrel external storage mounter[506]: no label, UUID=fbb2c40c-1880-4e06-9868-f4d6516d2c98
Jul 15 01:06:12 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
Jul 15 01:06:12 umbrel external storage mounter[506]: Starting external drive mount monitor…
Jul 15 01:06:12 umbrel external storage mounter[506]: Mount script completed successfully!
Jul 15 01:06:12 umbrel systemd[1]: Started External Storage Mounter.
Jul 15 01:06:15 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jul 15 01:06:15 umbrel external storage updater[1518]: Checking if SD card Umbrel is newer than external storage…
Jul 15 01:06:15 umbrel external storage updater[1518]: No, SD version is not newer, exiting.
Jul 15 01:06:15 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Attaching to
Tor logs
Attaching to
==== Result ====
