Umbrel Startup Service Failed! - failed to start containers
Havents found any good help figuring out how to fix my umbrel start up issues:
0.5.0
Flashed OS version
v0.4.18
Raspberry Pi Model
Revision : c03112
Serial : 1000000076b3affd
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=37.0’C
Throttling
throttled=0x0
Mem: 3.8G 141M 3.4G 8.0M 296M 3.6G
Swap: 4.1G 0B 4.1G
total: 3.7%
system: 3.7%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2023-02-28 01:19:09 Memory monitor running!
2023-02-28 01:19:21 Memory monitor running!
2023-02-28 01:19:33 Memory monitor running!
2023-02-28 01:19:45 Memory monitor running!
2023-02-28 01:19:56 Memory monitor running!
2023-02-28 01:20:08 Memory monitor running!
2023-02-28 01:20:20 Memory monitor running!
2023-02-28 01:20:32 Memory monitor running!
2023-02-28 01:20:43 Memory monitor running!
2023-02-28 01:20:55 Memory monitor running!
/dev/root 30G 3.2G 25G 12% /
/dev/sda1 916G 916G 0 100% /home/umbrel/umbrel
Startup service logs
Feb 28 01:20:55 umbrel umbrel startup[11908]: Starting backup monitor…
Feb 28 01:20:55 umbrel umbrel startup[11908]: Starting decoy backup trigger…
Feb 28 01:20:55 umbrel umbrel startup[11908]: Starting Docker services…
Feb 28 01:20:56 umbrel umbrel startup[11908]: The TOR_PROXY_PORT variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The NGINX_PORT variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The NGINX_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The MIDDLEWARE_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The UMBREL_AUTH_SECRET variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The BITCOIN_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The LND_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The AUTH_PORT variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The AUTH_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Feb 28 01:20:56 umbrel umbrel startup[11908]: The Compose file ‘./docker-compose.yml’ is invalid because:
Feb 28 01:20:56 umbrel umbrel startup[11908]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Feb 28 01:20:56 umbrel umbrel startup[11908]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Feb 28 01:20:56 umbrel umbrel startup[11908]: services.auth.ports contains an invalid type, it should be a number, or an object
Feb 28 01:20:56 umbrel umbrel startup[11908]: services.nginx.ports contains an invalid type, it should be a number, or an object
Feb 28 01:20:57 umbrel umbrel startup[11908]: Failed to start containers
Feb 28 01:20:57 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 28 01:20:57 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 28 01:20:57 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Tue 2023-02-28 01:12:33 UTC, end at Tue 2023-02-28 01:20:57 UTC. –
Feb 28 01:12:37 umbrel systemd[1]: Starting External Storage Mounter…
Feb 28 01:12:38 umbrel external storage mounter[479]: Running external storage mount script…
Feb 28 01:12:38 umbrel external storage mounter[479]: Found device “USB3.0 Super Speed”
Feb 28 01:12:38 umbrel external storage mounter[479]: Blacklisting USB device IDs against UAS driver…
Feb 28 01:12:38 umbrel external storage mounter[479]: Rebinding USB drivers…
Feb 28 01:12:38 umbrel external storage mounter[479]: Checking USB devices are back…
Feb 28 01:12:38 umbrel external storage mounter[479]: Waiting for USB devices…
Feb 28 01:12:39 umbrel external storage mounter[479]: Waiting for USB devices…
Feb 28 01:12:40 umbrel external storage mounter[479]: Checking if the device is ext4…
Feb 28 01:12:40 umbrel external storage mounter[479]: Yes, it is ext4
Feb 28 01:12:41 umbrel external storage mounter[479]: Checking if device contains an Umbrel install…
Feb 28 01:12:41 umbrel external storage mounter[479]: Yes, it contains an Umbrel install
Feb 28 01:12:41 umbrel external storage mounter[479]: Bind mounting external storage over local Umbrel installation…
Feb 28 01:12:41 umbrel external storage mounter[479]: Bind mounting external storage over local Docker data dir…
Feb 28 01:12:41 umbrel external storage mounter[479]: Bind mounting external storage to /swap
Feb 28 01:12:41 umbrel external storage mounter[479]: Bind mounting SD card root at /sd-card…
Feb 28 01:12:41 umbrel external storage mounter[479]: Checking Umbrel root is now on external storage…
Feb 28 01:12:42 umbrel external storage mounter[479]: Checking /var/lib/docker is now on external storage…
Feb 28 01:12:42 umbrel external storage mounter[479]: Checking /swap is now on external storage…
Feb 28 01:12:42 umbrel external storage mounter[479]: Setting up swapfile
Feb 28 01:12:42 umbrel external storage mounter[479]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Feb 28 01:12:42 umbrel external storage mounter[479]: no label, UUID=832f3cb4-740d-4cb4-9d91-3fb4c44b1465
Feb 28 01:12:42 umbrel external storage mounter[479]: Checking SD Card root is bind mounted at /sd-root…
Feb 28 01:12:42 umbrel external storage mounter[479]: Starting external drive mount monitor…
Feb 28 01:12:42 umbrel external storage mounter[479]: Mount script completed successfully!
Feb 28 01:12:42 umbrel systemd[1]: Started External Storage Mounter.
Feb 28 01:12:49 umbrel systemd[1]: Starting External Storage SDcard Updater…
Feb 28 01:12:49 umbrel external storage updater[872]: Checking if SD card Umbrel is newer than external storage…
Feb 28 01:12:49 umbrel external storage updater[872]: No, SD version is not newer, exiting.
Feb 28 01:12:49 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
karen is running in /home/umbrel/umbkaren is running in /home/umbrel/umbrel/events
Docker containers
Umbrel logs
Tor logs
This script requires “yq” to be installed
==== Result ====
Thanks for input
