See the terminal log:
0.5.2
Flashed OS version
v0.5.2
Raspberry Pi Model
Revision : d03114
Serial : 1000000036121fd4
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=34.0’C
Throttling
throttled=0x0
Mem: 7.8G 138M 7.0G 8.0M 629M 7.6G
Swap: 0B 0B 0B
total: 1.8%
system: 1.8%
Memory monitor logs
/dev/root 59G 2.9G 53G 6% /
Startup service logs
– Logs begin at Tue 2022-11-01 19:21:46 UTC, end at Tue 2022-11-01 20:07:53 UTC. –
– No entries –
External storage service logs
Nov 01 19:21:53 umbrel systemd[1]: Starting External Storage Mounter…
Nov 01 19:21:53 umbrel external storage mounter[482]: Running external storage mount script…
Nov 01 19:21:54 umbrel external storage mounter[482]: Found device “TOSHIBA External USB 3.0”
Nov 01 19:21:54 umbrel external storage mounter[482]: Blacklisting USB device IDs against UAS driver…
Nov 01 19:21:54 umbrel external storage mounter[482]: Checking USB devices are back…
Nov 01 19:21:54 umbrel external storage mounter[482]: Checking if the device is ext4…
Nov 01 19:21:54 umbrel external storage mounter[482]: Yes, it is ext4
Nov 01 19:21:54 umbrel external storage mounter[482]: Checking filesystem for corruption…
Nov 01 19:21:54 umbrel external storage mounter[482]: e2fsck 1.44.5 (15-Dec-2018)
Nov 01 19:21:57 umbrel external storage mounter[482]: umbrel was not cleanly unmounted, check forced.
Nov 01 19:21:57 umbrel external storage mounter[482]: Pass 1: Checking inodes, blocks, and sizes
Nov 01 20:04:13 umbrel external storage mounter[482]: Pass 2: Checking directory structure
Nov 01 20:07:10 umbrel systemd[1]: umbrel-external-storage.service: Start operation timed out. Terminating.
Nov 01 20:07:10 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=killed, status=15/TERM
– No entries –
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor Proxy logs
==== Result ====
umbrel@umbrel:~ $
