Umbrel is Unreachable after about 10 days
Ayer about 10 days, Umbrel become unreachable over the LAN. This happens often. I just pull the power and restart it.
I downloaded the system logs 17 hours later.
What am I looking for in their to tell me why this keeps happening?
Anyone else have this issue?
Have had this issue time and time again. To the point where I have given up on Umbrel. I have no faith in Umbrel what so ever. It looks nice but that is the end of it. Look elsewhere.
What alternative do you recommend?
At this stage I haven’t come up with alternative. I have shelved setting up a node for now.
I’ve also had a hell of a time.
  1. Experience this issue during initial sync.
  2. Had to restart umbrel to get sync to start again
  3. Sync on a Raspi 400 took >30 days (to a known good / brand new SSD, on a 500Mbps connection)
  4. Once synced, could not connect to bitcoin node directly with Sparrow.
  5. Installed electrs, but sync never completed (> 3 days, still says waiting for bitcoin node to sync)
  6. Attempted to re-index bitcoin node … now bitcoin node will not go past ~25% sync
  7. Inspection shows blockchain data is still present
  8. Umbrel activity monitor shows 0B for bitcoin node; bitcoin data appears to be associated with the system data now
    … there’s more that I’ve forgotten
TL;DR, I chose to use umbrel because it was supposed to be “easy mode” … now I’m realizing it would have been easier to just sync a node from scratch on a linux machine.
Unfortunate.
Read this thread!
[Umbrel Home Loses Network Connection]
Thank you for posting this Thread.
I don’t know much about coding and such but I wonder, would it help you to download angry IP? That helped me find the IP assigned to my home device.
Appreciate it, but I can see the device when I search for the IP. It just doesn’t respond.
Yes same here doesn’t find the IP address. I also use Mesh WiFi that shows all the IP address of everything connected on my network. Umbrel shows up on the Mesh but with no download or upload data . I can fix this by shutting it down and restarting, but give it a few days and same thing happens again.
This may be unrelated, but is Ubuntu the OS?
I moved all of my personal machines OFF of Ubuntu (Server) and installed Debian because out of the blue they would stop responding on the network. In the never-ending search of finding a way to fix the problem I would come across random Stack-Overflow or Ask Ubuntu posts instructing new parameters for ‘/etc/resolv.conf’ or something-something-it’s-always-DNS, etc.
After ditching Ubuntu (Ubuntu Server 20.4 was installed on 80% of them) and putting Debian 12 on each machine over the past couple of months, this problem has completely disappeared.
Just throwing this out there, hopefully it sparks some possible solution.
