Hi everyone, I installed umbrel on an old computer with SSD. umbrel starts correctly and tells me to reach the page via umbrel.local or IP address. everything works but after about 30 minutes I can no longer communicate with umbrel.local or ip address. I try to refresh the page but I get a loading error. I have to restart the computer and it works again. I can’t download the blockchain because every 30 minutes I would have to restart the computer. I downloaded the logs, if anyone can help me. Thank you
be sure your browser isnt “helping” you by adding the “s” to secure the link in https
You want http://
Hmm, that’s fun one. Can you share a bit more about the machine it’s running on and your network setup?
- Is this a virtual machine or physical?
- If physical can you share some of the specs (including the network card)
- When the issue appears, can you still interact with the umbrelOS shell on the command line?
- Do you have a busy network, like more than 100 devices connected?
Go ahead and share your log files if you can!
