Unable to log in
When I log on to Umbrel.local, I get "This site can’t be reached
umbrel’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE." Any solutions to get around this?
I would suggest using the Umbrel instance’s IP address instead. Try downloading angryip.org or fing.com, which will easily allow you to find your Umbrel’s IP, then you can just enter that in the browser. You should also try using ‘umbrel.local’ in Safari browser if that is an option for you.
Please let me know how you go with that, and then I can run you through some steps for fixing the umbrel.local address side.
I downloaded fing.com, found my umbrel ip address, entered it on a safari browser, I get " Error: Failed to start containers
Something went wrong when starting Umbrel. Need help? Feel free to jump on our community forum or Telegram chat." The Umbrel page allows me to restart, which I did several times. The page also allows me to shut down, which I did before unplugging the powerline to see if that would help clear out the issue, which it didn’t. I’m still unable to get in. Any other ideas is appreciated. Thanks
I finally got it to work by shutting everything down, unplugging the power source, resetting the router and powering everything back on. I’m sure I just got lucky but I’m not complaining. Onward…
