My Umbrel GUI is suddenly acting strange, and it is not showing the following parameters:
- Number of channels
- Blockchain data (wallet content not showing and sync % is at 0)
- Node temperature
- Storage used
- Ram used
I have rebooted both node and router, and it did not have any positive effect
Running Umbrel logs does not detect any problems, other than the tor logs showing a couple of warnings regarding “failing a very large amount of circuits.” Node temperature shows in the log - even if missing in GUI.
Mempool app has no issues, it is showing an updated mempool
RTL ses the correct on-chain balance which Umbrel GUI fails to show.
Node is routing and channels become active after a node reboot
No issues with the internet or power connections
So it looks like the node is humming along nicely, and that it is just the Umbrel GUI not updating.
I guess re-flashing the SD (again…) would be an option?
