Nothing in my umbrel dashboard seems to be running properly
My umbrel node has started behaving funny. When I visit the dashboard at umbrel.local, the UI just animates back and forth for Lightning, Bitcoin Wallet, and Bitcoin Core, but it never really finishes loading.
Has anybody had this problem? What would be a good way to troubleshoot this?
What I tried already when I noticed the problem
  • I ran the upgrade to 0.3.10 and let it restart. No noticeable change – the UI still animates endlessly.
  • I SSHed into the umbrel. I ran cd ~/umbrel/bin/ then ./bitcoin-cli getblockchaininfo. It took a few seconds to response, but gave a completely empty response.
  • I tried checking for error logs via SSH, but couldn’t find any that seemed relevant.
Please navigate to the “Settings” page and click “Troubleshoot → Start” to get more system information.
Just had the same thing. I disabled mempool then it said my wallet was locked, so I unlocked it by looking at the 24 secret words. I didn’t even have to enter them. Hope this helps.
This happened to me a lot when I had a HDD, so it’s possible that’s the issue. Otherwise, reflashing the SD card usually fixes most problems.
Having the same issues. Node always seems to be behind synchronizing the blockchain.
I was able to get debug log info by following directions from @blckbx
Error message says that it is most likely a power issue. I tried to get away with a different power supply, which seems to have been foolish. Surprisingly, it managed to sync to about 300,000 block height before failing. Now, upon rebooting the Umbrel, it can’t even seem to connect to the SSD (I was able to log in via SSH and verify it can’t get seem to mount the SSD via the syslog).
So I’m considering this fixed. I have my official 3 amp Raspberry Pi power cord on the way. If that doesn’t do the trick, I’ll post another question in the future. Thanks everyone! :grinning:
I am having the same problem since 5 hours ago. Then I found this thread, I tried to troubleshoot but it said no problems found. So I thought it needs to take a rest. I shut it down, restarted after one hour, and it’s still the same. :crazy_face:
@edward Are you sure there are no error messages contained within the troubleshooting log?
I, too, tried rebooting my node, but because I wasn’t getting enough power to the SSD, it couldn’t even finish loading the web UI after reboot. I was also able to see additional error messages by SSHint into the node and running less /var/log/sysylog. (I may have that path slightly wrong).
If you are still able to get into the web UI after rebooting, then I think your problem might be caused by something different than my problem (though it has some similar symptoms).
Current troubleshot message after I have changed my SDcard.
bitcoin | 2021-05-11T18:10:43Z Verifying last 6 blocks at level 3
bitcoin | 2021-05-11T18:10:43Z [0%]…LevelDB read failure: Corruption: not an sstable (bad magic number)
bitcoin | 2021-05-11T18:10:43Z Fatal LevelDB error: Corruption: not an sstable (bad magic number)
bitcoin | 2021-05-11T18:10:43Z You can use -debug=leveldb to get more complete diagnostic messages
bitcoin | 2021-05-11T18:10:43Z : Error opening block database.
bitcoin | Please restart with -reindex or -reindex-chainstate to recover.
bitcoin | 2021-05-11T18:10:43Z Aborted block database rebuild. Exiting.
bitcoin | 2021-05-11T18:10:43Z Shutdown: In progress…
bitcoin | : Error opening block database.
Because I’m not a programmer I have no idea what went wrong :expressionless:
Tor logs
Attaching to tor
tor | May 11 15:32:39.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor | May 11 15:32:51.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor | May 11 15:32:51.000 [notice] Bootstrapped 73% (loading_descriptors): Loading relay descriptors
tor | May 11 15:32:51.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | May 11 15:32:51.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor | May 11 15:32:51.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor | May 11 15:32:52.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor | May 11 15:32:52.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | May 11 15:32:52.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | May 11 15:32:53.000 [notice] Bootstrapped 100% (done): Done
tor | May 11 15:33:01.000 [warn] Guard NTH101 ($B5558CFA70A5308582B25767C9698E6DBE6A90B2) is failing an extremely large amount of circuits. This could indicate a route manipulation attack, extreme network overload, or a bug. Success counts are 3/151. Use counts are 2/2. 3 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 60 seconds.
tor | May 11 15:33:01.000 [warn] Guard NTH101 ($B5558CFA70A5308582B25767C9698E6DBE6A90B2) is failing a very large amount of circuits. Most likely this means the Tor network is overloaded, but it could also mean an attack against you or potentially the guard itself. Success counts are 60/176. Use counts are 50/50. 60 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 60 seconds.
tor | May 11 15:33:07.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 175 buildtimes.
tor | May 11 15:33:13.000 [notice] Guard NTH101 ($B5558CFA70A5308582B25767C9698E6DBE6A90B2) is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 172/246. Use counts are 107/107. 172 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 60 seconds.
tor | May 11 15:33:18.000 [notice] Tried for 120 seconds to get a connection to [scrubbed]:8333. Giving up. (waiting for rendezvous desc)
tor | May 11 15:33:28.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 221 buildtimes.
tor | May 11 15:33:38.000 [notice] We tried for 16 seconds to connect to ‘[scrubbed]’ using exit $6C143720FFF8469EF6A5C5B4066366340CF6C0D1~CalyxInstitute11 [FdTUD/tdltCelNIzLovsjNXKAPcq9mRAe6g1LvmDa0U] at 162.247.74.27. Retrying on a new circuit.
tor | May 11 15:34:06.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $8D912126FA40BD67EE7D5759BD19459450AEBEA1~BTCdonate [eEQWk3aM6dt+lc5MhG2tFf0j7mrj1Rnb4ni2hv47OTQ] at 46.41.148.75. Retrying on a new circuit.
tor | May 11 15:34:22.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $7761DDC7EB1BE26D4155F74A15F12C32A36FE0F2~CalyxInstitute09 [4aRzZCjmx6QGX3dlt+/VsTv4jOssd2aFdKSapiOoDSE] at 162.247.74.217. Retrying on a new circuit.
tor | May 11 15:34:46.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $3C89C80E2699FB6358BBB64FDC9547AFCB5C03F7~F3Netze [l1jD02S9qTqbElak0IR7Ea+Ov+bvuagFT8G53EVDbDY] at 185.220.100.240. Retrying on a new circuit.
tor | May 11 15:35:02.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $09F3067452D8D1DAFD33D0524A41DBF5295D3472~BASIS [BKYa/dCKhERRVp1fkwga8Ugwo1SqLL78IHBKTeck4Rw] at 45.125.65.118. Retrying on a new circuit.
tor | May 11 15:35:02.000 [notice] Tried for 123 seconds to get a connection to [scrubbed]:8333. Giving up.
tor | May 11 15:59:03.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $887CAB501A9DB68A2C44EDF98BF50B0304EED8B6~niftykostchtchie [aOmsqBCzWvW9eV9YaqzEpjf+iVobicNGwngG9OQgyK8] at 185.220.100.249. Retrying on a new circuit.
tor | May 11 15:59:18.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $08B73526414F3716C1CC5555411B35EB8DA50607~Hungary [XU52+RBWDFxttZ1woAJEp+tdRhBcQ4H48UlZWgdCJpE] at 91.219.237.21. Retrying on a new circuit.
tor | May 11 15:59:33.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $883A95D02E7EDE21640937FE74690B76B780DF66~squashbee [dh3xSd00k6MG7KjaMF/lTl+t7mc5K2f/JtzUuhC9Iok] at 51.75.122.240. Retrying on a new circuit.
tor | May 11 15:59:48.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $B0DD527BE01842D46030265FBD9928217A709F28~AccessNow005 [LvDyBh+ChAfMht/nQL5uXBndA78Vlb/6rik5jRAJN0I] at 176.10.99.205. Retrying on a new circuit.
tor | May 11 16:00:03.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $1AD9B8DAAC9CB67AD51D5B3BEE95C29D442FC4C6~CdgExitRelay [OF3l1x/gmJDskLAtIHvcAQucr4DspG3u1PIK3VnJa20] at 195.154.56.235. Retrying on a new circuit.
tor | May 11 16:00:18.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $08CE3DBFDAA27DB6C044A677AF68D7235C2AFC85~DigiGesTor4e4 [1vwKVjDxpr5w8yPeR391Rh7RWo3Zfzl1wEYqJ/EBv2c] at 195.176.3.20. Retrying on a new circuit.
tor | May 11 16:00:37.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $7B87EF57DAC332D7016C04AE82063E93B5162C44~Unnamed [l9j+jEhVfS4sy8SBBZ1m7obFwD256dW0yYrCgSnJluQ] at 51.158.65.243. Retrying on a new circuit.
tor | May 11 16:00:37.000 [notice] Tried for 132 seconds to get a connection to [scrubbed]:8333. Giving up.
==== Result ====
This is what it says.
Don’t worry I have no sats inside yet.
Mine also showing like this, UI is still in loading…it been more than 24 hours… what to do?
Not sure. From previous post I read they just said “be patient” :joy:
I’ll probably do another clean installation of it persists after another 24 hours
your answer good. but 391 GB size of blockchain data and my internet data limit is coming to an end for this month.
Lol
I’m having unlimited internet data, just feel kind of frustrated this happens after it reaches almost 90% synchronisation :joy::joy:
I just wanted a explorer like https://bitcoinblockexplorers.com/ this was my dream.
Seems that if you need to re-index the database, the following will work:
SSH in to your Raspberry Pi and type this command in to the terminal window:
$ sudo echo reindex=1 >> ~/umbrel/bitcoin/bitcoin.conf
Did anyone fix this issue? I am having the same issue as OP. My node stopped synchronizing and now just animates back and forth but doesn’t synch. I tried the reindex command and now the synchronized progress is 0% instead of 99.97%, which is what it was.
Had the same issue and just ended up resyncing and reflashing the SD card, only happened after I updated to 0.4.2
Wow, you had to resync the entire blockchain? I wonder if we can flash the sd card without resynching the node?
You can try it has worked for some, but I had a bunch of apps installed so I just redid everything.
