Umbrel going offline
I think this update solved my issue at least.
5 days straight no offline or any other issue whatsoever.
Will watch this for few more days and mark it as solution.
Regards
Sorry to hear about that @Doctore, can you provide us with the output of this command:
ssh -t umbrel@umbrel.local "journalctl | grep dhcp"
Fingers crossed here I’ve been up now just over 3 days, i deleted all the apps bar 2 and since then i haven’t had to power cycle, lost connection locally or over TOR, i will reinstall apps one by one over the next few days and see what happens.
Having the same issues. Umbrel runs good for a few hours (sometimes even two days) and then crashes and I have to disconnect power and restart. I also connected a monitor to my Pi, but it’s not displaying anything after a crash. Got the latest update.
Running on the hardware recommended on the Umbrel Website, except the SSD which is a Samsung Evo QVO 860 1TB.
Tried 3 different PSUs (including the official Raspi PSU).
Tried 3 different USB-SATA adapters (including the recommended one).
Since I got no access to the router, I have to use Wifi to connect.
I already tried reflashing the SD and formating the SSD.
I also SSH to Umbrel ssh -t umbrel@umbrel.local “journalctl | grep dhcp”
Last login: Wed Jul  7 17:42:21 2021 from 192.168.0.2
umbrel@umbrel:~ $ ssh -t umbrel@192.168.0.2 "journalctl | grep dhcp"
umbrel@192.168.0.2's password:
Jul 07 16:22:12 umbrel systemd[1]: Starting dhcpcd on all interfaces...
Jul 07 16:22:12 umbrel dhcpcd[373]: dev: loaded udev
Jul 07 16:22:12 umbrel dhcpcd[373]: wlan0: starting wpa_supplicant
Jul 07 16:22:12 umbrel dhcpcd-run-hooks[440]: wlan0: starting wpa_supplicant
Jul 07 16:22:12 umbrel dhcpcd[373]: wlan0: connected to Access Point `'
Jul 07 16:22:12 umbrel dhcpcd[373]: eth0: waiting for carrier
Jul 07 16:22:12 umbrel dhcpcd[373]: wlan0: waiting for carrier
Jul 07 16:22:17 umbrel dhcpcd[373]: wlan0: carrier acquired
Jul 07 16:22:17 umbrel dhcpcd[373]: wlan0: connected to Access Point `KabelBox-9        D98'
Jul 07 16:22:18 umbrel dhcpcd[373]: DUID 00:01:00:01:28:6d:f1:25:e4:5f:01:2c:f4:        c6
Jul 07 16:22:18 umbrel dhcpcd[373]: wlan0: IAID 01:2c:f4:c6
Jul 07 16:22:18 umbrel dhcpcd[373]: wlan0: adding address fe80::2c7e:93d2:855d:5        5cf
Jul 07 16:22:18 umbrel dhcpcd[373]: wlan0: soliciting an IPv6 router
Jul 07 16:22:18 umbrel dhcpcd[373]: wlan0: rebinding lease of 192.168.0.2
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: adding address 2a02:8109:a0c0:1283:58        59:f8d5:1c70:cd4f/64
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: adding route to 2a02:8109:a0c0:1283::        /64
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: requesting DHCPv6 information
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: fe80::ae22:5ff:feca:2f91 is reachable        again
Jul 07 16:22:19 umbrel kernel: ICMPv6: process `dhcpcd' is using deprecated sysc        tl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retran        s_time_ms instead
Jul 07 16:22:19 umbrel dhcpcd[373]: wlan0: adding default route via fe80::ae22:5        ff:feca:2f91
Jul 07 16:22:20 umbrel dhcpcd[373]: Too few arguments.
Jul 07 16:22:22 umbrel dhcpcd[373]: wlan0: probing address 192.168.0.2/24
Jul 07 16:22:24 umbrel dhcpcd[373]: forked to background, child pid 693
Jul 07 16:22:24 umbrel systemd[1]: Started dhcpcd on all interfaces.
Jul 07 16:22:28 umbrel dhcpcd[693]: wlan0: leased 192.168.0.2 for 604800 seconds
Jul 07 16:22:28 umbrel dhcpcd[693]: wlan0: adding route to 192.168.0.0/24
Jul 07 16:22:28 umbrel dhcpcd[693]: wlan0: adding default route via 192.168.0.1
Jul 07 16:22:29 umbrel dhcpcd[693]: wlan0: fe80::ae22:5ff:feca:2f91 is reachable        again
Jul 07 16:51:13 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 16:52:36 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 16:55:12 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 16:56:33 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 16:59:21 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:00:55 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:03:01 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:05:22 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:07:25 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:08:20 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:08:36 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:08:52 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:10:08 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:13:05 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:15:41 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:18:12 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:19:32 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:20:57 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:22:46 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:24:03 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:25:19 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:27:56 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:29:13 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:31:55 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:33:49 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:35:31 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:37:48 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:40:04 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Jul 07 17:41:34 umbrel dhcpcd[693]: wlan0: Router Advertisement from fe80::ae22:        5ff:feca:2f91
Connection to 192.168.0.2 closed.
umbrel@umbrel:~ $
Can please someone tell me what’s wrong? I’m not too tech savvy… Thank you!
EDIT: Just found out that I can still SSH after a crash…
Got the recommended Crucial MX500 now and looks like it solved the issues for me. No more crashes so far.
I have the same issue. How do I do that?
best,
