I assembled my Umbrel node with a raspberry Pi4, and NVMe M.2 SSD with Ugreen enclosure, but when I start it and connect to the node it indicates that there was a problem connecting to the storage device, has anyone used NVMe M.2 SSD when assembling your node and what solution have you found.
Unfortunately this is a common issue with NVMe and Raspberry Pi 4s Pi 4 8GB Low Voltage Warning on NVMe M.2 USB enclosure - Raspberry Pi Forums
NVMe requires more power than your normal SSD/HDD, which is why we usually recommend the following drive umbrelOS - An elegant OS for your home server https://a.co/d/6xJTtYe
While I have verified that this works myself, I’ve seen other people use powered USB hubs to make them work. Best Powered USB HUB For Raspberry Pi 4 In 2023 - Addicted To Tech
