0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03115
Serial : 10000000e5491007
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=48.7’C
Throttling
throttled=0x0
Mem: 7.8G 860M 3.6G 9.0M 3.4G 6.8G
Swap: 4.1G 0B 4.1G
bitcoin: 11.9%
total: 11.0%
system: 0%
Memory monitor logs
2023-11-02 23:53:10 Memory monitor running!
2023-11-03 22:34:32 Memory monitor running!
/dev/root 119G 5.0G 109G 5% /
/dev/sda1 916G 177G 693G 21% /home/umbrel/umbrel
Startup service logs
Nov 03 22:34:32 umbrel umbrel startup[1389]: Starting Docker services…
Nov 03 22:34:35 umbrel umbrel startup[1389]: Creating auth …
Nov 03 22:34:35 umbrel umbrel startup[1389]: Creating dashboard …
Nov 03 22:34:35 umbrel umbrel startup[1389]: Creating manager …
Nov 03 22:34:35 umbrel umbrel startup[1389]: Creating tor_proxy …
Nov 03 22:56:24 umbrel umbrel startup[1389]: Creating tor_proxy … done
Nov 03 22:56:25 umbrel umbrel startup[1389]: Creating auth … done
Nov 03 22:56:25 umbrel umbrel startup[1389]: Creating dashboard … done
Nov 03 22:56:25 umbrel umbrel startup[1389]: Creating manager … done
Nov 03 22:56:25 umbrel umbrel startup[1389]: Creating nginx …
Nov 03 22:56:30 umbrel umbrel startup[1389]: Creating nginx … done
Nov 03 22:56:31 umbrel umbrel startup[1389]: Removing status server iptables entry…
Nov 03 22:56:31 umbrel umbrel startup[1389]: Removed existing iptables entry.
Nov 03 22:56:31 umbrel umbrel startup[1389]: Starting installed apps…
Nov 03 22:56:31 umbrel umbrel startup[1389]: Starting app bitcoin…
Nov 03 22:56:31 umbrel umbrel startup[1389]: Executing hook: /home/umbrel/umbrel/app-data/bitcoin/hooks/pre-start
Nov 03 22:56:34 umbrel umbrel startup[1389]: Creating bitcoin_tor_1 …
Nov 03 22:56:34 umbrel umbrel startup[1389]: Creating bitcoin_bitcoind_1 …
Nov 03 22:56:34 umbrel umbrel startup[1389]: Creating bitcoin_i2pd_daemon_1 …
Nov 03 22:56:34 umbrel umbrel startup[1389]: Creating bitcoin_app_proxy_1 …
Nov 03 22:56:40 umbrel umbrel startup[1389]: Creating bitcoin_tor_1 … done
Nov 03 22:56:42 umbrel umbrel startup[1389]: Creating bitcoin_i2pd_daemon_1 … done
Nov 03 22:56:43 umbrel umbrel startup[1389]: Creating bitcoin_bitcoind_1 … done
Nov 03 22:56:43 umbrel umbrel startup[1389]: Creating bitcoin_server_1 …
Nov 03 22:56:43 umbrel umbrel startup[1389]: Creating bitcoin_app_proxy_1 … done
Nov 03 22:56:54 umbrel umbrel startup[1389]: Creating bitcoin_server_1 … done
Nov 03 22:56:55 umbrel umbrel startup[1389]: Umbrel is now accessible at
Nov 03 22:56:55 umbrel umbrel startup[1389]: http://umbrel.local
Nov 03 22:56:55 umbrel umbrel startup[1389]: http://192.168.100.6
Nov 03 22:56:55 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Nov 03 22:34:11 umbrel external storage mounter[482]: Rebinding USB drivers…
Nov 03 22:34:11 umbrel external storage mounter[482]: Checking USB devices are back…
Nov 03 22:34:11 umbrel external storage mounter[482]: Waiting for USB devices…
Nov 03 22:34:12 umbrel external storage mounter[482]: Waiting for USB devices…
Nov 03 22:34:13 umbrel external storage mounter[482]: Waiting for USB devices…
Nov 03 22:34:14 umbrel external storage mounter[482]: Checking if the device is ext4…
Nov 03 22:34:14 umbrel external storage mounter[482]: Yes, it is ext4
Nov 03 22:34:14 umbrel external storage mounter[482]: Checking filesystem for corruption…
Nov 03 22:34:14 umbrel external storage mounter[482]: e2fsck 1.44.5 (15-Dec-2018)
Nov 03 22:34:15 umbrel external storage mounter[482]: umbrel: recovering journal
Nov 03 22:34:20 umbrel external storage mounter[482]: Setting free inodes count to 60910702 (was 61054965)
Nov 03 22:34:20 umbrel external storage mounter[482]: Setting free blocks count to 193649098 (was 240075517)
Nov 03 22:34:20 umbrel external storage mounter[482]: umbrel: clean, 144274/61054976 files, 50541110/244190208 blocks
Nov 03 22:34:20 umbrel external storage mounter[482]: Mounting partition…
Nov 03 22:34:20 umbrel external storage mounter[482]: Checking if device contains an Umbrel install…
Nov 03 22:34:20 umbrel external storage mounter[482]: Yes, it contains an Umbrel install
Nov 03 22:34:20 umbrel external storage mounter[482]: Bind mounting external storage over local Umbrel installation…
Nov 03 22:34:20 umbrel external storage mounter[482]: Bind mounting external storage over local Docker data dir…
Nov 03 22:34:20 umbrel external storage mounter[482]: Bind mounting external storage to /swap
Nov 03 22:34:20 umbrel external storage mounter[482]: Bind mounting SD card root at /sd-card…
Nov 03 22:34:20 umbrel external storage mounter[482]: Checking Umbrel root is now on external storage…
Nov 03 22:34:21 umbrel external storage mounter[482]: Checking /var/lib/docker is now on external storage…
Nov 03 22:34:21 umbrel external storage mounter[482]: Checking /swap is now on external storage…
Nov 03 22:34:21 umbrel external storage mounter[482]: Setting up swapfile
Nov 03 22:34:23 umbrel external storage mounter[482]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 03 22:34:23 umbrel external storage mounter[482]: no label, UUID=1e3d09cb-9c2f-427a-8964-cd63b8245ec1
Nov 03 22:34:23 umbrel external storage mounter[482]: Checking SD Card root is bind mounted at /sd-root…
Nov 03 22:34:23 umbrel external storage mounter[482]: Starting external drive mount monitor…
Nov 03 22:34:23 umbrel external storage mounter[482]: Mount script completed successfully!
Nov 03 22:34:23 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Fri 2023-11-03 22:17:01 UTC, end at Fri 2023-11-03 23:02:07 UTC. –
Nov 03 22:34:32 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 03 22:34:32 umbrel external storage updater[1301]: Checking if SD card Umbrel is newer than external storage…
Nov 03 22:34:32 umbrel external storage updater[1301]: No, SD version is not newer, exiting.
Nov 03 22:34:32 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
9539 bytes (9.5 kB, 9.3 KiB) copied, 0.000457239 s, 20.9 MB/s
Creating encrypted tarball…
backup/
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:00:04 --:–:-- 0
100 10073 0 0 100 10073 0 1875 0:00:05 0:00:05 --:–:-- 1874
100 10219 100 146 100 10073 24 1703 0:00:06 0:00:05 0:00:01 1727
{“message”:“Successfully uploaded backup 1699034490439.tar.gz.pgp for backup ID 043ce90b3ddba548ea82a76a462d65e4def60a4267aa8070dff618753ba92b25”}
====== Backup success =======
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
1551 bytes (1.6 kB, 1.5 KiB) copied, 0.000258275 s, 6.0 MB/s
backup/
backup/.padding
Uploading backup…
100 2083 0 0 100 2083 0 357 0:00:05 0:00:05 --:–:-- 357
100 2229 100 146 100 2083 21 303 0:00:06 0:00:06 --:–:-- 324
{“message”:“Successfully uploaded backup 1699036299181.tar.gz.pgp for backup ID 043ce90b3ddba548ea82a76a462d65e4def60a4267aa8070dff618753ba92b25”}
Got signal:
Got signal:
Got signal: debug
Debug result file generated
Got signal: debug
Docker containers
NAMES STATUS
bitcoin_server_1 Up 5 minutes
bitcoin_i2pd_daemon_1 Up 5 minutes
bitcoin_app_proxy_1 Up 5 minutes
bitcoin_bitcoind_1 Up 5 minutes
bitcoin_tor_1 Up 5 minutes
nginx Up 5 minutes
tor_proxy Up 5 minutes
manager Up 5 minutes
dashboard Up 5 minutes
auth Up 5 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:04 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | umbrel-manager
manager |
manager | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:05 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:10 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 03 Nov 2023 23:02:12 GMT] “POST /v1/system/debug HTTP/1.0” 200 17 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 03 Nov 2023 23:02:13 GMT] “GET /v1/system/debug-result HTTP/1.0” 200 23 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 03 Nov 2023 23:02:14 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 03 Nov 2023 23:02:15 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:15 GMT] “GET /v1/account/token?token=419ea9f708f7421ea2638cf9cd9bda4b4290b1dcf5457b7966c1c51e26b29ffd HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 03 Nov 2023 23:02:16 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Nov 03 22:56:56.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 03 22:56:56.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 03 22:56:57.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_proxy | Nov 03 22:56:57.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Nov 03 22:56:58.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Nov 03 22:56:58.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Nov 03 22:56:59.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Nov 03 22:56:59.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Nov 03 22:56:59.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Nov 03 22:57:00.000 [notice] Bootstrapped 100% (done): Done
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1, bitcoin_tor_1
bitcoind_1 | 2023-11-03T23:00:57Z dnsseed thread start
bitcoind_1 | 2023-11-03T23:00:57Z opencon thread start
bitcoind_1 | 2023-11-03T23:00:57Z Waiting 300 seconds before querying DNS seeds.
bitcoind_1 | 2023-11-03T23:00:57Z msghand thread start
bitcoind_1 | 2023-11-03T23:00:57Z addcon thread start
bitcoind_1 | 2023-11-03T23:01:26Z UpdateTip: new best=000000000000000000a4a99d994692dded812bf9a541f6cad33fab986e38cf43 height=485404 version=0x20000012 log2_work=87.110636 tx=254648911 date=‘2017-09-15T12:43:18Z’ progress=0.286638 cache=1.2MiB(9292txo)
bitcoind_1 | 2023-11-03T23:01:48Z UpdateTip: new best=0000000000000000002b02d1ac5bc7ee4068e47125c8b4db4fb1f1b778b8ec0b height=485405 version=0x20000000 log2_work=87.110671 tx=254650825 date=‘2017-09-15T12:45:07Z’ progress=0.286640 cache=2.3MiB(17601txo)
bitcoind_1 | 2023-11-03T23:01:48Z init message: Done loading
bitcoind_1 | 2023-11-03T23:01:58Z UpdateTip: new best=000000000000000000b7e6705b4d6bf2581c1af7f37a5fba1caa0afc5919492f height=485406 version=0x20000000 log2_work=87.110705 tx=254653209 date=‘2017-09-15T12:55:29Z’ progress=0.286643 cache=3.4MiB(24818txo)
bitcoind_1 | 2023-11-03T23:02:10Z UpdateTip: new best=0000000000000000005d6d64763f80d4d0e7415c1b1916bc2284eb9aa78e28f0 height=485407 version=0x20000000 log2_work=87.110739 tx=254655254 date=‘2017-09-15T13:01:27Z’ progress=0.286645 cache=4.2MiB(31886txo)
app_proxy_1 | Validating token: 419ea9f708f7 …
i2pd_daemon_1 | 22:57:35@546/error - Tunnels: Can’t select next hop for fW1GTXl6~Wbv32RH96J4tggia-jgc3qtb7Kh0w2CPwI=
i2pd_daemon_1 | 22:57:35@546/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 22:57:40@546/error - Tunnels: Can’t select next hop for fW1GTXl6~Wbv32RH96J4tggia-jgc3qtb7Kh0w2CPwI=
i2pd_daemon_1 | 22:57:40@546/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 23:00:36@247/error - Addressbook: Empty response from shx5vqsw7usdaunyzr2qmes2fq37oumybpudrd4jjj4e4vk4uusa.b32.i2p, expected 0 bytes
i2pd_daemon_1 | 23:02:11@546/error - Tunnels: Can’t select next hop for zAVVX2i2gDTmvrc32AuZpHvkk5Zkd7BMFzqbfMcoPAw=
i2pd_daemon_1 | 23:02:11@546/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 23:02:12@829/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:05 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:10 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
server_1 | ::ffff:10.21.0.2 - - [Fri, 03 Nov 2023 23:02:15 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36”
server_1 |
tor_1 | Nov 03 22:57:05.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 03 22:57:06.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 03 22:57:06.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_1 | Nov 03 22:57:07.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Nov 03 22:57:08.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Nov 03 22:57:08.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Nov 03 22:57:08.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Nov 03 22:57:09.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Nov 03 22:57:09.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Nov 03 22:57:10.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
==== END =====
