The external drive was disconnected
The external drive was disconnected while Umbrel was running. This can sometimes happen when using an unofficial Raspberry Pi power supply."
Using Canakit Pi4 with 8GB RAM, Crucial MX500 SSD, replaced power supply already. Node runs and then randomly the SSD disconnects. I can usually restart the Pi and it begins syncing again but clearly this is broken. Same results with and without power adapter on/off switch.
Log attached
Umbrel logs
0.3.12
Umbrel OS version
v0.3.12
Raspberry Pi Model
Revision : d03114
Serial : 10000000db7624d0
Firmware
May 27 2021 14:02:15
Copyright © 2012 Broadcom
Temperature
temp=55.5’C
Throttling
throttled=0x0
Mem: 7.8G 995M 3.2G 8.0M 3.6G 7.0G
Swap: 4.1G 0B 4.1G
total: 12.8%
bitcoin: 7.4%
lnd: 4.5%
tor: 0.5%
system: 0.4%
electrs: 0%
Memory monitor logs
2021-06-14 15:18:40 Memory monitor running!
2021-06-14 15:50:10 Memory monitor running!
2021-06-14 16:41:59 Memory monitor running!
2021-06-15 01:02:06 Memory monitor running!
2021-06-15 11:37:47 Memory monitor running!
2021-06-15 12:19:46 Memory monitor running!
2021-06-15 14:51:43 Memory monitor running!
2021-06-16 02:17:28 Memory monitor running!
2021-06-16 11:17:13 Memory monitor running!
2021-06-16 11:57:15 Memory monitor running!
/dev/root 30G 2.9G 25G 11% /
/dev/sda1 916G 179G 691G 21% /home/umbrel/umbrel
Startup service logs
Jun 16 11:57:14 umbrel umbrel startup[1325]: Starting backup monitor…
Jun 16 11:57:14 umbrel umbrel startup[1325]: Starting decoy backup trigger…
Jun 16 11:57:14 umbrel umbrel startup[1325]: Starting Docker services…
Jun 16 11:57:17 umbrel umbrel startup[1325]: Starting electrs …
Jun 16 11:57:17 umbrel umbrel startup[1325]: Starting dashboard …
Jun 16 11:57:17 umbrel umbrel startup[1325]: Starting tor …
Jun 16 11:57:19 umbrel umbrel startup[1325]: Starting dashboard … done
Jun 16 11:57:19 umbrel umbrel startup[1325]: Starting electrs … done
Jun 16 11:57:19 umbrel umbrel startup[1325]: Starting tor … done
Jun 16 11:57:19 umbrel umbrel startup[1325]: Starting manager …
Jun 16 11:57:21 umbrel umbrel startup[1325]: Starting manager … done
Jun 16 11:57:21 umbrel umbrel startup[1325]: Starting lnd …
Jun 16 11:57:21 umbrel umbrel startup[1325]: Starting nginx …
Jun 16 11:57:22 umbrel umbrel startup[1325]: Starting nginx … done
Jun 16 11:57:22 umbrel umbrel startup[1325]: Starting bitcoin …
Jun 16 11:57:23 umbrel umbrel startup[1325]: Starting lnd … done
Jun 16 12:06:34 umbrel umbrel startup[1325]: Starting bitcoin … done
Jun 16 12:06:34 umbrel umbrel startup[1325]: Starting middleware …
Jun 16 12:06:34 umbrel umbrel startup[1325]: Starting neutrino-switcher …
Jun 16 12:06:36 umbrel umbrel startup[1325]: Starting middleware … done
Jun 16 12:06:36 umbrel umbrel startup[1325]: Starting neutrino-switcher … done
Jun 16 12:06:37 umbrel umbrel startup[1325]: Removing status server iptables entry…
Jun 16 12:06:37 umbrel umbrel startup[1325]: Removed existing iptables entry.
Jun 16 12:06:37 umbrel umbrel startup[1325]: Starting installed apps…
Jun 16 12:06:37 umbrel umbrel startup[1325]: Umbrel is now accessible at
Jun 16 12:06:37 umbrel umbrel startup[1325]: http://umbrel.local
Jun 16 12:06:37 umbrel umbrel startup[1325]: http://192.168.1.204
Jun 16 12:06:37 umbrel systemd[1]: Started Umbrel Startup Service.
Jun 16 12:07:28 umbrel passwd[3415]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
– Logs begin at Wed 2021-06-16 11:56:51 UTC, end at Wed 2021-06-16 12:07:57 UTC. –
Jun 16 11:56:55 umbrel systemd[1]: Starting External Storage Mounter…
Jun 16 11:56:55 umbrel external storage mounter[475]: Running external storage mount script…
Jun 16 11:56:55 umbrel external storage mounter[475]: Found device “ADplus SuperVer”
Jun 16 11:56:55 umbrel external storage mounter[475]: Blacklisting USB device IDs against UAS driver…
Jun 16 11:56:56 umbrel external storage mounter[475]: Rebinding USB drivers…
Jun 16 11:56:56 umbrel external storage mounter[475]: Checking USB devices are back…
Jun 16 11:56:56 umbrel external storage mounter[475]: Waiting for USB devices…
Jun 16 11:56:57 umbrel external storage mounter[475]: Waiting for USB devices…
Jun 16 11:56:58 umbrel external storage mounter[475]: Checking if the device is ext4…
Jun 16 11:56:58 umbrel external storage mounter[475]: Yes, it is ext4
Jun 16 11:57:00 umbrel external storage mounter[475]: Checking if device contains an Umbrel install…
Jun 16 11:57:00 umbrel external storage mounter[475]: Yes, it contains an Umbrel install
Jun 16 11:57:00 umbrel external storage mounter[475]: Bind mounting external storage over local Umbrel installation…
Jun 16 11:57:00 umbrel external storage mounter[475]: Bind mounting external storage over local Docker data dir…
Jun 16 11:57:00 umbrel external storage mounter[475]: Bind mounting external storage to /swap
Jun 16 11:57:00 umbrel external storage mounter[475]: Bind mounting SD card root at /sd-card…
Jun 16 11:57:00 umbrel external storage mounter[475]: Checking Umbrel root is now on external storage…
Jun 16 11:57:02 umbrel external storage mounter[475]: Checking /var/lib/docker is now on external storage…
Jun 16 11:57:02 umbrel external storage mounter[475]: Checking /swap is now on external storage…
Jun 16 11:57:02 umbrel external storage mounter[475]: Setting up swapfile
Jun 16 11:57:02 umbrel external storage mounter[475]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 16 11:57:02 umbrel external storage mounter[475]: no label, UUID=831e45fd-7706-48f2-9ceb-ddc58e7220f1
Jun 16 11:57:02 umbrel external storage mounter[475]: Checking SD Card root is bind mounted at /sd-root…
Jun 16 11:57:02 umbrel external storage mounter[475]: Starting external drive mount monitor…
Jun 16 11:57:02 umbrel external storage mounter[475]: Mount script completed successfully!
Jun 16 11:57:02 umbrel systemd[1]: Started External Storage Mounter.
Jun 16 11:57:14 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jun 16 11:57:14 umbrel external storage updater[1247]: Checking if SD card Umbrel is newer than external storage…
Jun 16 11:57:14 umbrel external storage updater[1247]: No, SD version is not newer, exiting.
Jun 16 11:57:14 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Uploading backup…
100 4740 100 146 100 4594 100 3146 0:00:01 0:00:01 --:–:-- 3248
{“message”:“Successfully uploaded backup 1623704332172.tar.gz.pgp for backup ID d8f8ca32125c7d0f136aa8840f49a3545a185de187839e5eaa1953a071a391e3”}
====== Backup success =======
Got signal: change-password
karen is getting triggered!
Got signal: debug
Debug result file generated
Got signal:
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
Got signal:
Got signal: debug
Got signal: debug
Docker containers
NAMES STATUS
neutrino-switcher Up 2 minutes
middleware Up 2 minutes
bitcoin Up 2 minutes
lnd Up 11 minutes
nginx Up 11 minutes
manager Up 11 minutes
tor Up 11 minutes
dashboard Up 11 minutes
electrs Up 11 minutes
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-06-16T12:08:25Z Rolling forward 0000000000000000001413d957a549115e938962a50a4b7b5b79a5138d7366e8 (496837)
bitcoin | 2021-06-16T12:08:25Z Rolling forward 000000000000000000b0e5102dfab00ed7ba6ab218238c74d0585053e5e868be (496838)
bitcoin | 2021-06-16T12:08:26Z Rolling forward 000000000000000000a311b252a38f86c5c1fd51cc48cbdfc33ca2bbf26ac2f3 (496839)
bitcoin | 2021-06-16T12:08:26Z Rolling forward 000000000000000000b0f7738353c02a6348746fc4225316f7911d90a2e1f09f (496840)
bitcoin | 2021-06-16T12:08:26Z Rolling forward 000000000000000000ccbc9b2afc4d755e01753c2b9a5b102b03e88e9f94d131 (496841)
bitcoin | 2021-06-16T12:08:27Z Rolling forward 0000000000000000001ee220c7c76e650f43c8a73b72f675549ac87cff5bda48 (496842)
bitcoin | 2021-06-16T12:08:27Z Rolling forward 000000000000000000b64fc4c2c0981ea81fa7b3cd1dcde8308864ee4f7ac954 (496843)
bitcoin | 2021-06-16T12:08:28Z Rolling forward 0000000000000000000fcca02fbb3eb55e367adabe250285483d7530cdba060b (496844)
bitcoin | 2021-06-16T12:08:28Z Rolling forward 000000000000000000097d7ce7c156c4185b10ad650ce369fd5317eeb6d641f0 (496845)
bitcoin | 2021-06-16T12:08:29Z Rolling forward 00000000000000000087ef317670b42c6a26411134fa184060cf39ba4abfe7bf (496846)
bitcoin | 2021-06-16T12:08:29Z Rolling forward 0000000000000000008adc8e36ea00acb8012e38ee8cb763caaa0e6093685054 (496847)
bitcoin | 2021-06-16T12:08:30Z Rolling forward 00000000000000000006a7832fca7a197682601b525e7c829db4769d0cdef022 (496848)
bitcoin | 2021-06-16T12:08:31Z Rolling forward 000000000000000000b8f25b2f782181f37c84480326935aaae91bbd1dfdc0eb (496849)
bitcoin | 2021-06-16T12:08:31Z Rolling forward 000000000000000000656e76cddb9fdc6c426d051e08a858249f920df84df2d1 (496850)
bitcoin | 2021-06-16T12:08:32Z Rolling forward 000000000000000000b83014c45feaecabfec01712def9c521d5cb7d72fdca4e (496851)
bitcoin | 2021-06-16T12:08:32Z Rolling forward 0000000000000000001d00f6c731ee5dd0736b8b0cb16f13766c912ef5892b56 (496852)
bitcoin | 2021-06-16T12:08:33Z Rolling forward 0000000000000000000b55241d4f4255ef536bf40f59f03d040643ac0c0efc85 (496853)
bitcoin | 2021-06-16T12:08:33Z Rolling forward 0000000000000000008938738f1a78d7422a013f257b98f2b6df5764948a9524 (496854)
bitcoin | 2021-06-16T12:08:34Z Rolling forward 0000000000000000008053ea0364c5c7af44c8bf9c85959d5a17b83c98b28fd6 (496855)
bitcoin | 2021-06-16T12:08:34Z Rolling forward 00000000000000000095eb793eb1d3f9ea1fbf426b6e7404b4f8e171cea5b0ff (496856)
bitcoin | 2021-06-16T12:08:35Z Rolling forward 00000000000000000064a3ec1956b8f931ab622e098209dc1452f3e4314cc123 (496857)
bitcoin | 2021-06-16T12:08:35Z Rolling forward 0000000000000000008744e60c2b2388ce8e7b5e29af8655e2c7cdea7b695478 (496858)
bitcoin | 2021-06-16T12:08:36Z Rolling forward 000000000000000000aa6444827ed40ba49f68e000c727ab77c686c0bfc73ada (496859)
bitcoin | 2021-06-16T12:08:36Z Rolling forward 000000000000000000210e3fbb29eb3a469102f5dbebf03b1e963294ea3404c4 (496860)
bitcoin | 2021-06-16T12:08:37Z Rolling forward 00000000000000000025ca1c3febdebab9e74a8fe67c184c70805476935ca5ec (496861)
bitcoin | 2021-06-16T12:08:38Z Rolling forward 00000000000000000022125b5c9490e7960904f2da0993cac2ca141474411e3c (496862)
bitcoin | 2021-06-16T12:08:38Z Rolling forward 0000000000000000008ec0ef3c3f292cefd9f0f9b7fa927b8dc98511ceeee21b (496863)
bitcoin | 2021-06-16T12:08:39Z Rolling forward 000000000000000000c031a0f4b746e5698c88a41a163168cc5cd5bf0ff77f5b (496864)
bitcoin | 2021-06-16T12:08:39Z Rolling forward 0000000000000000003678f6731076bc3426ce94dc4cb3b3245d22ae9bcf2aa7 (496865)
bitcoin | 2021-06-16T12:08:40Z Rolling forward 0000000000000000001c9b074acdb54995eacf7931f1892d36a2d55d04de07ab (496866)
LND logs
Attaching to lnd
lnd | 2021-06-16 12:07:47.487 [INF] BTCN: Lost peer 88.198.202.114:8333 (outbound)
lnd | 2021-06-16 12:07:47.554 [INF] BTCN: New valid peer 80.5.140.25:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-06-16 12:07:47.592 [INF] BTCN: Lost peer 80.5.140.25:8333 (outbound)
lnd | 2021-06-16 12:07:47.593 [WRN] BTCN: Banning peer 35.186.187.87:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:07:47.598 [INF] BTCN: Lost peer 35.186.187.87:8333 (outbound)
lnd | 2021-06-16 12:07:48.246 [WRN] BTCN: Unable to fetch set of candidate checkpoints, trying again…
lnd | 2021-06-16 12:07:48.628 [WRN] BTCN: Banning peer 91.77.165.170:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:07:48.629 [WRN] BTCN: Banning peer 54.251.65.228:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:07:48.637 [INF] BTCN: Lost peer 91.77.165.170:8333 (outbound)
lnd | 2021-06-16 12:07:48.646 [INF] BTCN: Lost peer 54.251.65.228:8333 (outbound)
lnd | 2021-06-16 12:07:48.754 [WRN] BTCN: Banning peer 34.92.235.236:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:07:48.762 [INF] BTCN: Lost peer 34.92.235.236:8333 (outbound)
lnd | 2021-06-16 12:07:50.562 [WRN] BTCN: Banning peer 18.231.114.211:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:07:50.565 [INF] BTCN: Lost peer 18.231.114.211:8333 (outbound)
lnd | 2021-06-16 12:07:51.079 [INF] BTCN: New valid peer 80.109.75.19:8333 (outbound) (/btcwire:0.5.0/btcd:0.22.0/)
lnd | 2021-06-16 12:08:01.247 [WRN] BTCN: Unable to fetch set of candidate checkpoints, trying again…
lnd | 2021-06-16 12:08:09.481 [WRN] BTCN: Banning peer 161.35.179.139:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:08:09.483 [INF] BTCN: Lost peer 161.35.179.139:8333 (outbound)
lnd | 2021-06-16 12:08:10.075 [INF] BTCN: New valid peer 95.211.139.215:8333 (outbound) (/btcwire:0.5.0/btcd:0.21.0/)
lnd | 2021-06-16 12:08:10.288 [WRN] BTCN: Banning peer 188.32.14.31:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:08:10.290 [INF] BTCN: Lost peer 188.32.14.31:8333 (outbound)
lnd | 2021-06-16 12:08:10.380 [INF] BTCN: Lost peer 95.211.139.215:8333 (outbound)
lnd | 2021-06-16 12:08:10.892 [WRN] BTCN: Banning peer 34.78.14.25:8333: duration=48h0m0s, reason=peer was unable to serve compact filters
lnd | 2021-06-16 12:08:10.896 [INF] BTCN: Lost peer 34.78.14.25:8333 (outbound)
lnd | 2021-06-16 12:08:12.943 [INF] BTCN: New valid peer 72.197.241.112:8333 (outbound) (/Satoshi:0.21.1/)
lnd | 2021-06-16 12:08:13.977 [INF] BTCN: New valid peer 172.86.181.59:8333 (outbound) (/btcwire:0.5.0/btcd:0.22.0/)
lnd | 2021-06-16 12:08:14.238 [INF] BTCN: Lost peer 172.86.181.59:8333 (outbound)
lnd | 2021-06-16 12:08:14.248 [WRN] BTCN: Unable to fetch set of candidate checkpoints, trying again…
lnd | 2021-06-16 12:08:27.250 [WRN] BTCN: Unable to fetch set of candidate checkpoints, trying again…
lnd | 2021-06-16 12:08:40.250 [WRN] BTCN: Unable to fetch set of candidate checkpoints, trying again…
Tor logs
Attaching to tor
tor | Jun 16 11:57:19.966 [notice] Opened Control listener connection (ready) on 10.21.21.11:29051
tor | Jun 16 11:57:20.000 [notice] Bootstrapped 0% (starting): Starting
tor | Jun 16 11:57:20.000 [notice] Starting with guard context “default”
tor | Jun 16 11:57:21.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | Jun 16 11:57:22.000 [notice] Bootstrapped 100% (done): Done
tor | Jun 16 12:06:38.000 [notice] Your system clock just jumped 556 seconds forward; assuming established circuits no longer work.
tor | Jun 16 12:06:46.000 [warn] Guard RNVR217 ($41EEC4CFA01E8982643F1AF3CD84315329D2B58E) is failing an extremely large amount of circuits. This could indicate a route manipulation attack, extreme network overload, or a bug. Success counts are 36/151. Use counts are 23/23. 36 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 74 seconds.
tor | Jun 16 12:06:46.000 [warn] Guard RNVR217 ($41EEC4CFA01E8982643F1AF3CD84315329D2B58E) is failing a very large amount of circuits. Most likely this means the Tor network is overloaded, but it could also mean an attack against you or potentially the guard itself. Success counts are 65/207. Use counts are 49/49. 65 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 74 seconds.
tor | Jun 16 12:06:46.000 [notice] Guard RNVR217 ($41EEC4CFA01E8982643F1AF3CD84315329D2B58E) is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 128/213. Use counts are 99/99. 128 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 74 seconds.
tor | Jun 16 12:07:18.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 867 buildtimes.
tor | Jun 16 12:07:24.000 [notice] We tried for 16 seconds to connect to ‘[scrubbed]’ using exit $719FD0FA327F3CCBCDA0D4EA74C15EA110338942~F3Netze [Nx05iIqVlLft1v1insRjzT1YbtgXFX+qRtxygcI7GC8] at 185.220.100.252. Retrying on a new circuit.
tor | Jun 16 12:07:27.000 [notice] Guard hellebuz ($52D5FB2004C67127C73B71478238FA66122BD443) is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 123/179. Use counts are 462/462. 123 circuits completed, 0 were unusable, 0 collapsed, and 0 timed out. For reference, your timeout cutoff is 60 seconds.
tor | Jun 16 12:07:28.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 117 buildtimes.
tor | Jun 16 12:07:52.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $1FC55B6E54789CB4AEF1F5A9D35C4420789AB5DE~VrijHeid3 [pd2krqre3HkNf77pZEGQMZIdcTjdIkhCqCKhGl6C4zg] at 94.142.241.194. Retrying on a new circuit.
tor | Jun 16 12:08:02.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F8E9C0C3A4B61E7599AA7A23D7ADE77E5BAB2663~relayon0122 [kK8L/Rq8Dpf8cY+T8HUEA10rahEpoJlFxYgjvugyulM] at 185.220.101.3. Retrying on a new circuit.
tor | Jun 16 12:08:07.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F8E9C0C3A4B61E7599AA7A23D7ADE77E5BAB2663~relayon0122 [kK8L/Rq8Dpf8cY+T8HUEA10rahEpoJlFxYgjvugyulM] at 185.220.101.3. Retrying on a new circuit.
tor | Jun 16 12:08:08.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Jun 16 12:08:13.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | Jun 16 12:08:24.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $702FD318AEED49702B5C16255ED5F595DA116516~Ubermensch [3lHo1ZQy/KzSSEXGllrLsDsRcYzvkuqPP5u2aLeXv8Q] at 51.210.80.127. Retrying on a new circuit.
tor | Jun 16 12:08:25.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $702FD318AEED49702B5C16255ED5F595DA116516~Ubermensch [3lHo1ZQy/KzSSEXGllrLsDsRcYzvkuqPP5u2aLeXv8Q] at 51.210.80.127. Retrying on a new circuit.
tor | Jun 16 12:08:39.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F57770B67D45090E98BCFA93FDDDDFB656040E83~TenAndTwo [O8SkQPuOi0UacjzmZ5p3h65Sqa+tb/haYzkMdJolAYI] at 198.144.120.177. Retrying on a new circuit.
tor | Jun 16 12:08:40.000 [notice] We tried for 15 seconds to connect to ‘[scrubbed]’ using exit $F57770B67D45090E98BCFA93FDDDDFB656040E83~TenAndTwo [O8SkQPuOi0UacjzmZ5p3h65Sqa+tb/haYzkMdJolAYI] at 198.144.120.177. Retrying on a new circuit.
==== Result ====
I am having this same issue. If I am lucky it lasts 20 minutes before telling me that the hard drive has disconnected. I am using all of the recommended equipment and I have re-flashed the SD card many times. The blue lights is still on and blinking even after I get the message.
My issue ended up being an ssd case/cable issue and I bought a new cable that went straight from the ssd to the umbrel and the problem solved immediately. I stopped using the ssd case
Thank you! That appears to be what my issue was too. I bought an Apricorn SATA USB cable and it has been working for over an hour now.
