Hi all,
My node apps are stopped on installing/updating. I followed the pinned troubleshooting guide and successfully used it to resolve at first.
However, after installing an app or two, the issue persisted for more apps. I tried the solution again and it worked, however… my blockchain sync had reset. I tried using the troubleshooting for bad shutdown resulting in unsyncing of the blockchain, but it did not work.
So I had to redownload the blockchain, and once again I am having the app download “loading”.
Is there anything I can try for the app install issue to be permanently fixed? Or any other suggestions? Thank you.
Running latest version of Umbrel on Raspberry Pi w/ SSD
