Can't install any apps!
Hi everyone, I just got this Umbrel Home and haven’t been able to install any apps yet! What am I doing wrong?
I have installed the latest version, UmbrelOS 1.4.2
log.txt (184.4 KB)
Explain what you are doing. You are logged into the web interface, and it won’t let you select?
I would like to install the Bitcoin Node app.
When I click on it, it shows “installing” for about 3 seconds, and then it becomes inactive.
The icon is visible, but when I click on it, it says “restart” and then the icon disappears.
This happens with all the other apps I try to install as well.
It’s been like this since the day I received the device! Even with previous versions, I haven’t been able to install anything.
However, I was able to update to version 1.4.2 via USB stick.
