Hi All - I’m trying to update my Umbrel Home from version 0.5.3 to version 1.0.0; however, it is stuck on “Starting Update…”.
I tried the steps in this link to factory reset my Umbrel Home.
First I reset the Umbrel Home using the command (screenshot attached):
However, I am getting stuck; after I insert the flashed USB into the Umbel and turn it back on, the Umbrel does not automatically reflash and turn off; the device just stays on and keeps running.
When I go to umbrel.local, there is an error (see attached).
Any advice is much appreciated.
Thank you in advance.
