Factory Reset (Umbrel Home)
Due to the failed upgrade to 1.0 on my Umbrel Home, I decided to completely reset it. If anyone can help me, here’s the thread: Umbrel home - sitting @ 20% done for 1.0 upgrade - #15 by denny
However, if there is no way to save it, then I would like to do a factory reset. How can I do this? :bomb:
I found instructions: Unanswered questions about the Umbrel Home – Daechler's Blog
Does anyone know if this guide is up to date?
It worked! :grin:
I used them to reset mine
I’m glad it worked out for you. :slightly_smiling_face:
