Tested on two Umbrel instances, version 1.7.3, tor is unusable, stuck at:
Bootstrapped 30% (loading_status): Loading networkstatus consensus
On one Umbrel I went ahead with “Factory reset”, hoping it would fix it. But the issue persists.
So even without any apps installed yet, with the only two containers:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
d2d16f574bb1 getumbrel/auth-server:1.7.0 "docker-entrypoint.s…" 7 minutes ago Up 7 minutes 0.0.0.0:2000->2000/tcp, [::]:2000->2000/tcp auth
e20fb7f03b1c getumbrel/tor:0.4.7.8 "tor" 7 minutes ago Up 6 minutes tor_proxy
root@umbrel:~# docker logs -f -n 20 tor_proxy
Jul 09 18:10:59.000 [notice] Starting with guard context "default"
Jul 09 18:11:00.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
Jul 09 18:11:01.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
Jul 09 18:11:01.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
Jul 09 18:11:01.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
Jul 09 18:11:01.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
Jul 09 18:11:01.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
Jul 09 18:11:01.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
Jul 09 18:11:01.000 [warn] Received http status code 404 ("Consensus not signed by sufficient number of requested authorities") from server xxxxxxxxxxxxxx:9001 while fetching consensus directory.
Jul 09 18:11:07.000 [warn] Received http status code 404 ("Consensus not signed by sufficient number of requested authorities") from server xxxxxxxxxxxxxxx:443 while fetching consensus directory.
Jul 09 18:15:17.000 [warn] Received http status code 404 ("Consensus not signed by sufficient number of requested authorities") from server xxxxxxxxxxxxxxxx:80 while fetching consensus directory.
Jul 09 18:17:35.000 [warn] Problem bootstrapping. Stuck at 30% (loading_status): Loading networkstatus consensus. (Connection timed out; TIMEOUT; count 10; recommendation warn; host xxxxxxxxxxxxxxxxxxx at xxxxxxxxxxxxx)
Jul 09 18:17:35.000 [warn] 9 connections have failed:
Jul 09 18:17:35.000 [warn] 9 connections died in state connect()ing with SSL state (No SSL object)
Jul 09 18:18:16.000 [warn] Problem bootstrapping. Stuck at 30% (loading_status): Loading networkstatus consensus. (Connection timed out; TIMEOUT; count 11; recommendation warn; host xxxxxxxxxx at xxxxxxxxxxxxxxxxxxx)
Jul 09 18:18:16.000 [warn] 10 connections have failed:
Jul 09 18:18:16.000 [warn] 10 connections died in state connect()ing with SSL state (No SSL object)
Jul 09 18:18:26.000 [warn] Problem bootstrapping. Stuck at 30% (loading_status): Loading networkstatus consensus. (Connection refused; CONNECTREFUSED; count 12; recommendation warn; host xxxxxxxxxxxxxxxxxxxxxx at xxxxxxxxxxxxxx)
Jul 09 18:18:26.000 [warn] 11 connections have failed:
Jul 09 18:18:26.000 [warn] 11 connections died in state connect()ing with SSL state (No SSL object)
And it doesn’t progress past 30% ever…
I also replied to this issue, it looks related: Tor 0.4.7.8 in app sidecar containers cannot fetch directory authority certs — all hidden services broken, zero inbound connectivity · Issue #2151 · getumbrel/umbrel · GitHub
Anyone else has this issue and knows a fix?
