The applications have been in "Starting" mode
Hello! I have installed in Umbrel “Bitcoin Core” (Already with all the blocks validated) “Electr” “Lightning Node” and “Mempool” when restarting Umbrel all the applications have been in “Starting” mode it takes more than 12 hours.
Do you know how I can solve it?
Thank you!
I have the same issue:
Sure enough, the problem was Tor. I was able to solve it with the command: sudo systemctl stop tor
Thank you gospelcrypto. Your the real gospel!
