"This website cannot be accessed" problem
Hello
Until today I was connecting to Umbrel without problems but suddenly I can’t access the Umbrel interface anymore, I get a message that “this website cannot be accessed”. I’ve been checking the connections for days, the IP address, MAC, and I don’t know what to look for. Something must have been misconfigured but I can’t find the problem to solve it. I would appreciate if you could guide me on how to solve it. Greetings and thank you.
Hi @Bosco, just to confirm, have you tried scanning your local network for a new IP that your Umbrel might be accessible by? https://angryip.org/
Most common cause of this issue is your router changing the IP address
Well yes, that was it. The IP had changed and I have already accessed again. Thank you.
I am having the same problem, My Umbrel is on the same IP as before this problem started, And i have the same problem when I try to log into this ip directly on safari. Angryip did not pick up the IP address. Any help?
Here are a few steps you can take to troubleshoot the “This website cannot be accessed” issue:
  1. Check Network Connections: Ensure your device is properly connected to the same network as your Umbrel server.
  2. Verify IP Address: Confirm that the IP address of the Umbrel device is correct. Try accessing it using the direct IP address rather than the hostname.
  3. Restart the Device: Reboot your Umbrel server and any routers or modems to refresh the connection.
  4. Check for Firewall Issues: Ensure that no firewall or security settings are blocking the connection to Umbrel.
  5. Clear Browser Cache: Sometimes, cached data can interfere with loading the page. Clear your browser’s cache and try again.
  6. Use Alternative Devices or Browsers: Try accessing the interface from a different device or browser to rule out any browser-specific issues.
We’ve faced a similar problem on this site2024-11-27T19:00:00Z, and these troubleshooting steps helped resolve the issue. If the problem persists, you may want to reach out to Umbrel’s support for more specific assistance.
