Any suggestions before I reformat my SD and reinstall Umbrel?
0.5.3
Flashed OS version
v0.4.1
Raspberry Pi Model
Revision : d03114
Serial : 100000000a42cf81
Firmware
Aug 3 2021 18:14:56
Copyright © 2012 Broadcom
version 40787ee5905644f639a2a0f6e00ae12e517a2211 (clean) (release) (start)
Temperature
temp=43.8’C
Throttling
throttled=0x0
Mem: 7.8G 154M 6.8G 390M 864M 7.1G
Swap: 4.1G 0B 4.1G
total: 2.0%
system: 2%
pi-hole: 0%
mempool: 0%
lightning: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2019-02-14 10:30:48 Memory monitor running!
18393 ? R 0:00 bash ./scripts/memory-monitor
2019-02-14 10:31:15 Memory monitor running!
2019-02-14 10:31:28 Memory monitor running!
2019-02-14 10:31:42 Memory monitor running!
2019-02-14 10:31:56 Memory monitor running!
2019-02-14 10:32:09 Memory monitor running!
2019-02-14 10:32:23 Memory monitor running!
2019-02-14 10:32:36 Memory monitor running!
/dev/root 30G 30G 0 100% /
/dev/sda1 916G 608G 263G 70% /home/umbrel/umbrel
Startup service logs
Feb 14 14:55:34 umbrel systemd[1]: Stopped Umbrel Startup Service.
Feb 14 14:55:34 umbrel systemd[1]: Starting Umbrel Startup Service…
Feb 14 14:55:34 umbrel umbrel startup[29751]: /home/umbrel/umbrel/scripts/…/scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Feb 14 14:55:34 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 14:55:34 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 14:55:34 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Feb 14 14:55:44 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Feb 14 14:55:44 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 1629.
Feb 14 14:55:44 umbrel systemd[1]: Stopped Umbrel Startup Service.
Feb 14 14:55:44 umbrel systemd[1]: Starting Umbrel Startup Service…
Feb 14 14:55:44 umbrel umbrel startup[29818]: /home/umbrel/umbrel/scripts/…/scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Feb 14 14:55:44 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 14:55:44 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 14:55:44 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Feb 14 14:55:54 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Feb 14 14:55:54 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 1630.
Feb 14 14:55:54 umbrel systemd[1]: Stopped Umbrel Startup Service.
Feb 14 14:55:54 umbrel systemd[1]: Starting Umbrel Startup Service…
Feb 14 14:55:54 umbrel umbrel startup[29885]: /home/umbrel/umbrel/scripts/…/scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Feb 14 14:55:54 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 14:55:54 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 14:55:54 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Feb 14 14:56:05 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Feb 14 14:56:05 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 1631.
Feb 14 14:56:05 umbrel systemd[1]: Stopped Umbrel Startup Service.
Feb 14 14:56:05 umbrel systemd[1]: Starting Umbrel Startup Service…
Feb 14 14:56:05 umbrel umbrel startup[30450]: /home/umbrel/umbrel/scripts/…/scripts/umbrel-os/status-server/set-status: line 31: echo: write error: No space left on device
Feb 14 14:56:05 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 14:56:05 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 14:56:05 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Thu 2019-02-14 12:01:50 UTC, end at Thu 2019-02-14 14:56:05 UTC. –
– No entries –
– No entries –
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Attaching to manager
Tor Proxy logs
Attaching to tor_proxy
App logs
bitcoin
Attaching to
electrs
Attaching to
lightning
Attaching to
mempool
Attaching to
pi-hole
Attaching to
==== Result ====
