Hello.
I was updating my umbrel and the update stalled on “running umbrel migrations” My computer then got restarted.
I have tried to reflash my SD and have run sudo reboot but still arrive at the same “running umbrel migrations” screen when i try to access through umbrel.local.
Thanks
0.5.3
Flashed OS version
v0.3.14
Raspberry Pi Model
Revision : d03114
Serial : 10000000cd4b2395
Firmware
May 27 2021 14:02:15
Copyright (c) 2012 Broadcom
Temperature
temp=40.9’C
Throttling
throttled=0x0
Mem: 7.8G 161M 7.2G 16M 417M 7.5G
Swap: 4.1G 0B 4.1G
total: 2.1%
system: 2.1%
thunderhub: 0%
specter-desktop: 0%
simple-torrent: 0%
samourai-server: 0%
ride-the-lightning: 0%
plex: 0%
nostr-relay: 0%
mempool: 0%
ln-visualizer: 0%
lnmarkets: 0%
lightning-shell: 0%
lightning: 0%
kollider: 0%
jellyfin: 0%
jam: 0%
electrs: 0%
core-lightning: 0%
bitcoin: 0%
Memory monitor logs
2019-02-14 10:15:37 Memory monitor running!
2019-02-14 10:15:51 Memory monitor running!
2019-02-14 10:16:04 Memory monitor running!
2019-02-14 10:16:18 Memory monitor running!
2019-02-14 10:16:31 Memory monitor running!
2019-02-14 10:16:45 Memory monitor running!
2019-02-14 10:16:58 Memory monitor running!
2019-02-14 10:17:11 Memory monitor running!
2019-02-14 10:17:25 Memory monitor running!
2019-02-14 10:17:39 Memory monitor running!
/dev/root 29G 29G 0 100% /
/dev/sda1 916G 602G 269G 70% /home/umbrel/umbrel
Startup service logs
Feb 14 10:17:39 umbrel umbrel startup[19365]: Starting status monitors…
Feb 14 10:17:39 umbrel umbrel startup[19365]: Starting memory monitor…
Feb 14 10:17:39 umbrel umbrel startup[19365]: Starting backup monitor…
Feb 14 10:17:39 umbrel umbrel startup[19365]: Starting decoy backup trigger…
Feb 14 10:17:39 umbrel umbrel startup[19365]: Starting Docker services…
Feb 14 10:17:41 umbrel umbrel startup[19365]: Starting manager …
Feb 14 10:17:41 umbrel umbrel startup[19365]: Starting tor_server …
Feb 14 10:17:41 umbrel umbrel startup[19365]: Starting dashboard …
Feb 14 10:17:41 umbrel umbrel startup[19365]: Starting tor_proxy …
Feb 14 10:17:41 umbrel umbrel startup[19365]: Starting auth …
Feb 14 10:17:42 umbrel umbrel startup[19365]: Starting manager … error
Feb 14 10:17:42 umbrel umbrel startup[19365]: ERROR: for manager Cannot start service manager: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 10:17:42 umbrel umbrel startup[19365]: Starting tor_server … error
Feb 14 10:17:42 umbrel umbrel startup[19365]: ERROR: for tor_server Cannot start service tor_server: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 10:17:42 umbrel umbrel startup[19365]: Starting dashboard … error
Feb 14 10:17:42 umbrel umbrel startup[19365]: ERROR: for dashboard Cannot start service dashboard: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 10:17:42 umbrel umbrel startup[19365]: Starting tor_proxy … error
Feb 14 10:17:42 umbrel umbrel startup[19365]: ERROR: for tor_proxy Cannot start service tor_proxy: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 10:17:42 umbrel umbrel startup[19365]: Starting auth … error
Feb 14 10:17:42 umbrel umbrel startup[19365]: ERROR: for auth Cannot start service auth: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 10:17:42 umbrel umbrel startup[19365]: Encountered errors while bringing up the project.
Feb 14 10:17:42 umbrel umbrel startup[19365]: Failed to start containers
Feb 14 10:17:42 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 10:17:42 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 10:17:42 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
Feb 14 10:12:04 umbrel external storage mounter[493]: Checking USB devices are back…
Feb 14 10:12:04 umbrel external storage mounter[493]: Waiting for USB devices…
Feb 14 10:12:05 umbrel external storage mounter[493]: Waiting for USB devices…
Feb 14 10:12:06 umbrel external storage mounter[493]: Waiting for USB devices…
Feb 14 10:12:07 umbrel external storage mounter[493]: Checking if the device is ext4…
Feb 14 10:12:07 umbrel external storage mounter[493]: Yes, it is ext4
Feb 14 10:12:07 umbrel external storage mounter[493]: Checking filesystem for corruption…
Feb 14 10:12:07 umbrel external storage mounter[493]: e2fsck 1.44.5 (15-Dec-2018)
Feb 14 10:12:08 umbrel external storage mounter[493]: Superblock last mount time is in the future.
Feb 14 10:12:08 umbrel external storage mounter[493]: (by less than a day, probably due to the hardware clock being incorrectly set)
Feb 14 10:12:08 umbrel external storage mounter[493]: Superblock last write time is in the future.
Feb 14 10:12:08 umbrel external storage mounter[493]: umbrel: clean, 755401/61054976 files, 161668702/244190208 blocks
Feb 14 10:12:08 umbrel external storage mounter[493]: Mounting partition…
Feb 14 10:12:08 umbrel external storage mounter[493]: Checking if device contains an Umbrel install…
Feb 14 10:12:08 umbrel external storage mounter[493]: Yes, it contains an Umbrel install
Feb 14 10:12:08 umbrel external storage mounter[493]: Bind mounting external storage over local Umbrel installation…
Feb 14 10:12:08 umbrel external storage mounter[493]: Bind mounting external storage over local Docker data dir…
Feb 14 10:12:08 umbrel external storage mounter[493]: Bind mounting external storage to /swap
Feb 14 10:12:08 umbrel external storage mounter[493]: Bind mounting SD card root at /sd-card…
Feb 14 10:12:08 umbrel external storage mounter[493]: Checking Umbrel root is now on external storage…
Feb 14 10:12:09 umbrel external storage mounter[493]: Checking /var/lib/docker is now on external storage…
Feb 14 10:12:09 umbrel external storage mounter[493]: Checking /swap is now on external storage…
Feb 14 10:12:09 umbrel external storage mounter[493]: Setting up swapfile
Feb 14 10:12:09 umbrel external storage mounter[493]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Feb 14 10:12:09 umbrel external storage mounter[493]: no label, UUID=49d5268e-0426-492c-8460-11950d3c8dc7
Feb 14 10:12:09 umbrel external storage mounter[493]: Checking SD Card root is bind mounted at /sd-root…
Feb 14 10:12:09 umbrel external storage mounter[493]: Starting external drive mount monitor…
Feb 14 10:12:09 umbrel external storage mounter[493]: Mount script completed successfully!
Feb 14 10:12:09 umbrel systemd[1]: Started External Storage Mounter.
Feb 14 10:12:17 umbrel external storage updater[915]: =======================================
Feb 14 10:12:17 umbrel external storage updater[915]: =============== UPDATE ================
Feb 14 10:12:17 umbrel external storage updater[915]: =========== Stage: Install ============
Feb 14 10:12:17 umbrel external storage updater[915]: =============================================
Feb 14 10:12:17 umbrel external storage updater[915]: Installing on Umbrel OS v0.3.14
Feb 14 10:12:17 umbrel external storage updater[915]: ./01-run.sh: line 25: cannot create temp file for here-document: No space left on device
Feb 14 10:12:17 umbrel external storage updater[915]: == End Update Script 01-run.sh ==
Feb 14 10:12:17 umbrel external storage updater[915]: == Begin Update Script 02-run.sh ==
Feb 14 10:12:17 umbrel external storage updater[915]: ========= Stage: Post-update ==========
Feb 14 10:12:17 umbrel external storage updater[915]: == End Update Script 02-run.sh ==
Feb 14 10:12:17 umbrel external storage updater[915]: == Begin Update Script 03-run.sh ==
Feb 14 10:12:17 umbrel external storage updater[915]: =========== Stage: Success ============
Feb 14 10:12:17 umbrel external storage updater[915]: Removing backup
Feb 14 10:12:17 umbrel external storage updater[915]: ./03-run.sh: line 19: cannot create temp file for here-document: No space left on device
Feb 14 10:12:17 umbrel external storage updater[915]: == End Update Script 03-run.sh ==
Feb 14 10:12:17 umbrel external storage updater[915]: Deleting cloned repository
Feb 14 10:12:17 umbrel external storage updater[915]: Removing lock
Feb 14 10:12:25 umbrel external storage updater[915]: /home/umbrel/umbrel/scripts/update/update: line 173: cannot create temp file for here-document: No space left on device
Feb 14 10:12:25 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
18446 ? R 0:00 bash ./karen
karen is already running
Docker containers
NAMES STATUS
Umbrel logs
Attaching to manager
Tor Proxy logs
Attaching to tor_proxy
App logs
bitcoin
Attaching to
core-lightning
Attaching to
electrs
Attaching to
jam
Attaching to
jellyfin
Attaching to
kollider
Attaching to
lightning
Attaching to
lightning-shell
Attaching to
ln-visualizer
Attaching to
lnmarkets
Attaching to
mempool
Attaching to
nostr-relay
Attaching to
plex
Attaching to
ride-the-lightning
Attaching to
samourai-server
Attaching to
simple-torrent
Attaching to
specter-desktop
Attaching to
thunderhub
Attaching to
==== Result ====
umbrel@umbrel:~ $ Connection to umbrel.local closed by remote host.
