Umbrel was working until internet and power went. I was able to log into the dash but apps were stuck loading. I decided to do a fresh start by reformatting the sd card and ssd. I reflashed the sd card to umbrel lastest version several times but continue to get Error system service fail on the dashboard. I’m looking to start fresh with the umbrel. I was able to get these logs. Any step by step help is appreciated. It’s been 3 days of trial and error
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision :
Serial :
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=40.9’C
Throttling
throttled=0x0
Mem: 7.8G 250M 6.6G 8.0M 1.0G 7.4G
Swap: 4.1G 0B 4.1G
total: 3.2%
system: 3.2%
Memory monitor logs
2023-11-16 02:19:07 Memory monitor running!
/dev/root 350G 21G 316G 7% /
/dev/sda1 916G 4.7G 865G 1% /home/umbrel/umbrel
Startup service logs
Nov 16 02:18:41 umbrel umbrel startup[915]: a0af8e57cd93: Verifying Checksum
Nov 16 02:18:41 umbrel umbrel startup[915]: a0af8e57cd93: Download complete
Nov 16 02:18:49 umbrel umbrel startup[915]: 60197a4c18d4: Pull complete
Nov 16 02:18:54 umbrel umbrel startup[915]: a0af8e57cd93: Pull complete
Nov 16 02:18:55 umbrel umbrel startup[915]: 34c083c26e18: Pull complete
Nov 16 02:19:01 umbrel umbrel startup[915]: Digest: sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a
Nov 16 02:19:01 umbrel umbrel startup[915]: Status: Downloaded newer image for getumbrel/tor@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a
Nov 16 02:19:07 umbrel umbrel startup[915]: Configuring permissions…
Nov 16 02:19:07 umbrel umbrel startup[915]: Configuration successful
Nov 16 02:19:07 umbrel umbrel startup[915]: You can now start Umbrel by running:
Nov 16 02:19:07 umbrel umbrel startup[915]: sudo ./scripts/start
Nov 16 02:19:07 umbrel umbrel startup[915]: ======================================
Nov 16 02:19:07 umbrel umbrel startup[915]: ============= STARTING ===============
Nov 16 02:19:07 umbrel umbrel startup[915]: ============== UMBREL ================
Nov 16 02:19:07 umbrel umbrel startup[915]: Setting environment variables…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting karen…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting status monitors…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting memory monitor…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting backup monitor…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting decoy backup trigger…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting umbreld…
Nov 16 02:19:07 umbrel umbrel startup[915]: Starting Docker services…
Nov 16 02:19:29 umbrel umbrel startup[915]: Creating network “umbrel_main_network” with the default driver
Nov 16 02:19:29 umbrel umbrel startup[915]: Pulling dashboard (getumbrel/dashboard:0.5.4@sha256:0662567cc1b0ba2179f65bfae0472d085a7e79f53f502e8d1789a1ecba58744b)…
Nov 16 02:19:45 umbrel umbrel startup[915]: docker.io/getumbrel/dashboard@sha256:0662567cc1b0ba2179f65bfae0472d085a7e79f53f502e8d1789a1ecba58744b: Pulling from getumbrel/dashboard
Nov 16 02:20:59 umbrel umbrel startup[915]: Digest: sha256:0662567cc1b0ba2179f65bfae0472d085a7e79f53f502e8d1789a1ecba58744b
Nov 16 02:20:59 umbrel umbrel startup[915]: Status: Downloaded newer image for getumbrel/dashboard@sha256:0662567cc1b0ba2179f65bfae0472d085a7e79f53f502e8d1789a1ecba58744b
Nov 16 02:20:59 umbrel umbrel startup[915]: Pulling manager (getumbrel/manager:0.5.4@sha256:400559b951ec19b9e79c5eec96bf2a11efd57a7f9c65f9a8cc03e6ff833e9a59)…
Nov 16 02:21:45 umbrel umbrel startup[915]: docker.io/getumbrel/manager@sha256:400559b951ec19b9e79c5eec96bf2a11efd57a7f9c65f9a8cc03e6ff833e9a59: Pulling from getumbrel/manager
External storage service logs
Nov 16 02:11:43 umbrel external storage mounter[503]: Found device “Samsung PSSD T7”
Nov 16 02:11:43 umbrel external storage mounter[503]: Blacklisting USB device IDs against UAS driver…
Nov 16 02:16:49 umbrel external storage mounter[503]: Rebinding USB drivers…
Nov 16 02:16:49 umbrel external storage mounter[503]: Checking USB devices are back…
Nov 16 02:16:49 umbrel external storage mounter[503]: Waiting for USB devices…
Nov 16 02:16:50 umbrel external storage mounter[503]: Waiting for USB devices…
Nov 16 02:16:51 umbrel external storage mounter[503]: Waiting for USB devices…
Nov 16 02:16:52 umbrel external storage mounter[503]: Checking if the device is ext4…
Nov 16 02:17:07 umbrel external storage mounter[503]: Yes, it is ext4
Nov 16 02:17:07 umbrel external storage mounter[503]: Checking filesystem for corruption…
Nov 16 02:17:07 umbrel external storage mounter[503]: e2fsck 1.44.5 (15-Dec-2018)
Nov 16 02:17:11 umbrel external storage mounter[503]: umbrel: clean, 713/61054976 files, 4128389/244190208 blocks
Nov 16 02:17:11 umbrel external storage mounter[503]: Mounting partition…
Nov 16 02:17:12 umbrel external storage mounter[503]: Checking if device contains an Umbrel install…
Nov 16 02:17:12 umbrel external storage mounter[503]: Yes, it contains an Umbrel install
Nov 16 02:17:12 umbrel external storage mounter[503]: Bind mounting external storage over local Umbrel installation…
Nov 16 02:17:12 umbrel external storage mounter[503]: Bind mounting external storage over local Docker data dir…
Nov 16 02:17:12 umbrel external storage mounter[503]: Bind mounting external storage to /swap
Nov 16 02:17:12 umbrel external storage mounter[503]: Bind mounting SD card root at /sd-card…
Nov 16 02:17:12 umbrel external storage mounter[503]: Checking Umbrel root is now on external storage…
Nov 16 02:17:34 umbrel external storage mounter[503]: Checking /var/lib/docker is now on external storage…
Nov 16 02:17:34 umbrel external storage mounter[503]: Checking /swap is now on external storage…
Nov 16 02:17:34 umbrel external storage mounter[503]: Setting up swapfile
Nov 16 02:17:34 umbrel external storage mounter[503]: rm: cannot remove ‘/swap/swapfile’: No such file or directory
Nov 16 02:17:34 umbrel external storage mounter[503]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 16 02:17:34 umbrel external storage mounter[503]: no label, UUID=c968b898-496f-4ce9-ad8a-97ff0504c965
Nov 16 02:17:34 umbrel external storage mounter[503]: Checking SD Card root is bind mounted at /sd-root…
Nov 16 02:17:34 umbrel external storage mounter[503]: Starting external drive mount monitor…
Nov 16 02:17:34 umbrel external storage mounter[503]: Mount script completed successfully!
Nov 16 02:17:34 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Thu 2023-11-16 02:10:36 UTC, end at Thu 2023-11-16 02:22:19 UTC. –
Nov 16 02:17:42 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 16 02:17:42 umbrel external storage updater[838]: Checking if SD card Umbrel is newer than external storage…
Nov 16 02:17:42 umbrel external storage updater[838]: No, SD version is not newer, exiting.
Nov 16 02:17:42 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Attaching to
Tor Proxy logs
Attaching to
==== Result ====
==== END =====
