Receiving "Error: System service failed"
Hello, I’m having some issues I was hoping I could get some help with. I had to reflash the SD card for my Umbrel due to an issue and after flashing it, the Umbrel GUI now shows “Error: System service failed”.
I ran ~/umbrel/scripts/debug --upload and it came back with this:
0.4.7
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision        : d03114
Serial          : 10000000e9527de4
Model           : Raspberry Pi 4 Model B Rev 1.4
Firmware
Oct 29 2021 10:47:33
Copyright (c) 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=28.2'C
Throttling
throttled=0x0
Mem:           7.8G        136M        7.4G        8.0M        315M        7.6G
Swap:          4.1G          0B        4.1G
total: 1.8%
system: 1.8%
tor: 0%
thunderhub: 0%
squeaknode: 0%
sphinx-relay: 0%
specter-desktop: 0%
ride-the-lightning: 0%
pi-hole: 0%
nextcloud: 0%
mempool: 0%
lnd: 0%
lightning-terminal: 0%
electrs: 0%
btc-rpc-explorer: 0%
bluewallet: 0%
bitcoin: 0%
Memory monitor logs
2021-10-10 17:20:16 Memory monitor running!
2021-10-26 23:01:59 Memory monitor running!
2021-11-01 08:40:16 Memory monitor running!
2021-11-05 02:07:47 Memory monitor running!
2021-11-08 03:44:22 Memory monitor running!
 5143 ?        S      0:03 bash ./scripts/memory-monitor
 5143 ?        S      0:09 bash ./scripts/memory-monitor
2021-11-13 17:03:24 Memory monitor running!
/dev/root       117G  3.1G  110G   3% /
/dev/sda1       1.8T  485G  1.3T  28% /home/umbrel/umbrel
Startup service logs
-- Logs begin at Tue 2021-11-16 07:49:19 UTC, end at Tue 2021-11-16 08:00:50 UTC. --
Nov 16 07:49:38 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 16 07:49:38 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result 'dependency'.
External storage service logs
Nov 16 07:49:24 umbrel systemd[1]: Starting External Storage Mounter...
Nov 16 07:49:24 umbrel external storage mounter[512]: Running external storage mount script...
Nov 16 07:49:26 umbrel external storage mounter[512]: Found device "SABRENT "
Nov 16 07:49:26 umbrel external storage mounter[512]: Blacklisting USB device IDs against UAS driver...
Nov 16 07:49:26 umbrel external storage mounter[512]: Rebinding USB drivers...
Nov 16 07:49:26 umbrel external storage mounter[512]: Checking USB devices are back...
Nov 16 07:49:26 umbrel external storage mounter[512]: Waiting for USB devices...
Nov 16 07:49:27 umbrel external storage mounter[512]: Waiting for USB devices...
Nov 16 07:49:28 umbrel external storage mounter[512]: Checking if the device is ext4...
Nov 16 07:49:28 umbrel external storage mounter[512]: Yes, it is ext4
Nov 16 07:49:28 umbrel external storage mounter[512]: Checking if device contains an Umbrel install...
Nov 16 07:49:28 umbrel external storage mounter[512]: Yes, it contains an Umbrel install
Nov 16 07:49:28 umbrel external storage mounter[512]: Bind mounting external storage over local Umbrel installation...
Nov 16 07:49:28 umbrel external storage mounter[512]: Bind mounting external storage over local Docker data dir...
Nov 16 07:49:28 umbrel external storage mounter[512]: Bind mounting external storage to /swap
Nov 16 07:49:28 umbrel external storage mounter[512]: Bind mounting SD card root at /sd-card...
Nov 16 07:49:28 umbrel external storage mounter[512]: Checking Umbrel root is now on external storage...
Nov 16 07:49:29 umbrel external storage mounter[512]: Checking /var/lib/docker is now on external storage...
Nov 16 07:49:29 umbrel external storage mounter[512]: Checking /swap is now on external storage...
Nov 16 07:49:29 umbrel external storage mounter[512]: Setting up swapfile
Nov 16 07:49:30 umbrel external storage mounter[512]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 16 07:49:30 umbrel external storage mounter[512]: no label, UUID=8c260ce5-906b-4fa3-949b-0429576469f1
Nov 16 07:49:30 umbrel external storage mounter[512]: Checking SD Card root is bind mounted at /sd-root...
Nov 16 07:49:30 umbrel external storage mounter[512]: Starting external drive mount monitor...
Nov 16 07:49:30 umbrel external storage mounter[512]: Mount script completed successfully!
Nov 16 07:49:30 umbrel systemd[1]: Started External Storage Mounter.
Nov 16 07:49:38 umbrel systemd[1]: Starting External Storage SDcard Updater...
Nov 16 07:49:38 umbrel external storage updater[1037]: Checking if SD card Umbrel is newer than external storage...
Nov 16 07:49:38 umbrel external storage updater[1037]: Yes, SD version is newer.
Nov 16 07:49:38 umbrel external storage updater[1037]: Checking if the external storage version "0.4.7" satisfies update requirement ">=0.2.1"...
Nov 16 07:49:38 umbrel external storage updater[1037]: Yes, it does, attempting an automatic update...
Nov 16 07:49:38 umbrel external storage updater[1037]: =======================================
Nov 16 07:49:38 umbrel external storage updater[1037]: =============== UPDATE ================
Nov 16 07:49:38 umbrel external storage updater[1037]: ========== Stage: Download ============
Nov 16 07:49:38 umbrel external storage updater[1037]: An update is already in progress. Exiting now.
Nov 16 07:49:38 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Nov 16 07:49:38 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Failed with result 'exit-code'.
Nov 16 07:49:38 umbrel systemd[1]: Failed to start External Storage SDcard Updater.
Karen logs
Stopping Docker services...
Stopping middleware         ...
Stopping bitcoin            ...
Stopping nginx              ...
Stopping lnd                ...
Stopping manager            ...
Stopping dashboard          ...
Stopping electrs            ...
Stopping umbrel_app_tor_1   ...
Stopping tor                ...
Stopping umbrel_app_2_tor_1 ...
Stopping umbrel_app_3_tor_1 ...
Stopping umbrel_app_2_tor_1 ... done
Stopping umbrel_app_3_tor_1 ... done
Stopping umbrel_app_tor_1   ... done
Stopping middleware         ... done
Stopping electrs            ... done
Stopping lnd                ... done
Stopping bitcoin            ... done
Stopping nginx              ... done
Stopping manager            ... done
Stopping dashboard          ... done
Stopping tor                ... done
Removing middleware         ...
Removing neutrino-switcher  ...
Removing bitcoin            ...
Removing nginx              ...
Removing lnd                ...
Removing manager            ...
Removing dashboard          ...
Removing electrs            ...
Removing umbrel_app_tor_1   ...
Removing tor                ...
Removing umbrel_app_2_tor_1 ...
Removing umbrel_app_3_tor_1 ...
Removing dashboard          ... done
Removing electrs            ... done
Removing umbrel_app_3_tor_1 ... done
Removing umbrel_app_2_tor_1 ... done
Removing neutrino-switcher  ... done
Removing lnd                ... done
Removing bitcoin            ... done
Removing middleware         ... done
Removing umbrel_app_tor_1   ... done
Removing manager            ... done
Removing nginx              ... done
Removing tor                ... done
Docker containers
NAMES     STATUS
Umbrel logs
Attaching to
Bitcoin Core logs
Attaching to
LND logs
Attaching to
electrs logs
Attaching to
Tor logs
Attaching to
App logs
bluewallet
Attaching to
btc-rpc-explorer
Attaching to
lightning-terminal
Attaching to
mempool
Attaching to
nextcloud
Attaching to
pi-hole
Attaching to
ride-the-lightning
Attaching to
specter-desktop
Attaching to
sphinx-relay
Attaching to
squeaknode
Attaching to
thunderhub
Attaching to
==== Result ====
I also ran docker container ls and it looks like there are no containers? I would think LND should be there, if not more.
Does anyone know what the issue could be? Would it be due to the Umbrel OS being different from the flashed OS? Or something else?
Thanks in advance.
Is right there the error…
So your update is not finished.
In the troubleshooting manual there’s a section about manually update. See there instructions about how to deal with this “an update is already in progress”
Thanks you’re right. It’s all good now thanks for the help.
