Hi.
I just got my node assembled and plugged in since yesterday. I have been getting “Error: System service failed” when trying to access it from my desktop browser (Brave). I am thinking the problem is possibly with my T-Mobile 5g home internet, which when I set it up warned me that accessing devices on the local network would be different than normal. I have already tried to find information on that from T-Mobile and called their support and they were not able to help right away, though the issue has been escalated. I can see the device is connected on my router dashboard and it shows the IP address, which when I type in to the browser takes me to the same error screen as umbrel.local.
Or it could be something to do with the external SSD. I have bolded the relevant lines in the debug log below, though I don’t know exactly how to interpret what I’m reading. Any help would be appreciated. Thanks.
0.4.9
Flashed OS version
v0.4.9
Raspberry Pi Model
Revision : c03111
Serial : 100000000f2ee198
Firmware
Oct 29 2021 10:47:33
Copyright © 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=45.7’C
Throttling
throttled=0x0
Mem: 3.8G 125M 3.5G 8.0M 209M 3.6G
Swap: 0B 0B 0B
total: 3.3%
system: 3.3%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 29G 1.7G 27G 6% /
Startup service logs
– Logs begin at Fri 2021-12-17 17:55:40 UTC, end at Fri 2021-12-17 20:48:47 UTC. –
Dec 17 17:55:47 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Dec 17 17:55:47 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Dec 17 17:55:44 umbrel systemd[1]: Starting External Storage Mounter…
Dec 17 17:55:44 umbrel external storage mounter[484]: Running external storage mount script…
Dec 17 17:55:44 umbrel external storage mounter[484]: Found device “Argon Forty”
Dec 17 17:55:44 umbrel external storage mounter[484]: Blacklisting USB device IDs against UAS driver…
Dec 17 17:55:44 umbrel external storage mounter[484]: Rebinding USB drivers…
Dec 17 17:55:44 umbrel external storage mounter[484]: Checking USB devices are back…
Dec 17 17:55:44 umbrel external storage mounter[484]: Waiting for USB devices…
Dec 17 17:55:45 umbrel external storage mounter[484]: Waiting for USB devices…
Dec 17 17:55:46 umbrel external storage mounter[484]: Checking if the device is ext4…
Dec 17 17:55:47 umbrel external storage mounter[484]: No, it’s not ext4
Dec 17 17:55:47 umbrel external storage mounter[484]: Formatting device…
Dec 17 17:55:47 umbrel external storage mounter[484]: wipefs: error: /dev/sda: probing initialization failed: No medium found
Dec 17 17:55:47 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Dec 17 17:55:47 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Dec 17 17:55:47 umbrel systemd[1]: Failed to start External Storage Mounter.
Dec 17 17:55:47 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Dec 17 17:55:47 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
services.tor.ports contains an invalid type, it should be a number, or an object
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
