Error: System service failed, help a noob
Hello. I am new to setting up a bitcoin Node and decided to go with Umbrel as my first try. I am currently stuck and getting the [Resolving “Error: System service failed”] error. I have perused the forum here and seems that the threads I have found addressing this issue are very limited. Hence my posting.
I am using a Raspberry Pi4. I have tried re-flashing the SD card but that does not work and I keep getting the same error. I have also try, restarting Umbrel and restarting my PC. Nothing works and as I said, I am new to this so I might be overlooking the obvious.
Thanks for the help!
