I’ve gone through many similar posts, and have not had success yet. Seems like its an external hard drive connection issue. I think we had a power outage /internet outage last night - before that I’ve been up and running for months.
I have reflashed with both 4.6 and 4.5 to no avail. Hints? Tips? tricks?
0.4.5
Flashed OS version
v0.4.5
Raspberry Pi Model
Revision : d03114
Serial : 10000000a0739417
Firmware
Sep 30 2021 19:21:03
Copyright © 2012 Broadcom
version 51215b4f6e3966401ecd99652a35cf1c25069113 (clean) (release) (start)
Temperature
temp=52.5’C
Throttling
throttled=0x0
Mem: 7.8G 131M 7.4G 8.0M 264M 7.6G
Swap: 0B 0B 0B
total: 1.7%
system: 1.7%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 59G 1.7G 55G 3% /
Startup service logs
– Logs begin at Wed 2021-11-10 00:16:52 UTC, end at Wed 2021-11-10 00:34:40 UTC. –
Nov 10 00:19:12 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 10 00:19:12 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Nov 10 00:16:57 umbrel systemd[1]: Starting External Storage Mounter…
Nov 10 00:16:57 umbrel external storage mounter[487]: Running external storage mount script…
Nov 10 00:16:58 umbrel external storage mounter[487]: No block devices found
Nov 10 00:16:58 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:17:03 umbrel external storage mounter[487]: No block devices found
Nov 10 00:17:03 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:17:08 umbrel external storage mounter[487]: No block devices found
Nov 10 00:17:08 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:17:13 umbrel external storage mounter[487]: No block devices found
Nov 10 00:17:13 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:17:18 umbrel external storage mounter[487]: No block devices found
Nov 10 00:17:18 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:17:23 umbrel external storage mounter[487]: No block devices found
Nov 10 00:17:23 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:19:04 umbrel external storage mounter[487]: No block devices found
Nov 10 00:19:04 umbrel external storage mounter[487]: Waiting for 5 seconds before checking again…
Nov 10 00:19:09 umbrel external storage mounter[487]: Found device “CT1000MX 500SSD1”
Nov 10 00:19:09 umbrel external storage mounter[487]: Blacklisting USB device IDs against UAS driver…
Nov 10 00:19:10 umbrel external storage mounter[487]: Rebinding USB drivers…
Nov 10 00:19:10 umbrel external storage mounter[487]: Checking USB devices are back…
Nov 10 00:19:10 umbrel external storage mounter[487]: Waiting for USB devices…
Nov 10 00:19:11 umbrel external storage mounter[487]: Waiting for USB devices…
Nov 10 00:19:12 umbrel external storage mounter[487]: Checking if the device is ext4…
Nov 10 00:19:12 umbrel external storage mounter[487]: Yes, it is ext4
Nov 10 00:19:12 umbrel external storage mounter[487]: mount: /mnt/data: special device /dev/sda1 does not exist.
Nov 10 00:19:12 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=32/n/a
Nov 10 00:19:12 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Nov 10 00:19:12 umbrel systemd[1]: Failed to start External Storage Mounter.
Nov 10 00:19:12 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 10 00:19:12 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
services.tor.ports contains an invalid type, it should be a number, or an object
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:mJuysIUt7Aydp5vwM1mDK/6mc4hfoyLOvZvOdqdU6rY.
Please contact your system administrator.
Add correct host key in C:\Users\Owner/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in C:\Users\Owner/.ssh/known_hosts:1
ECDSA host key for umbrel.local has changed and you have requested strict checking.
Host key verification failed.
