Hello, Umbrel community.
My Umbrel node had been working perfectly fine, until 13 days ago I started to have an issue syncronizing Bitcoin Core on my Raspberry Pi 4 Model B Rev 1.4 (Umbrel version 0.4.17).
As far as I understood from log-file, Bitcoin Core is not able to read seeds to start sync from. The Umbrel node is located in Russia. Is it possible that Russian ISP blocked seed list addresses? Like it happened in Iran? And what could be a solution for that problem?
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2022-04-23T09:25:13Z Loaded 68017 addresses from peers.dat 1449ms
bitcoin | 2022-04-23T09:25:14Z Loaded 0 addresses from “anchors.dat”
bitcoin | 2022-04-23T09:25:14Z 0 block-relay-only anchors will be tried for connections.
bitcoin | 2022-04-23T09:25:14Z init message: Starting network threads…
bitcoin | 2022-04-23T09:25:14Z net thread start
bitcoin | 2022-04-23T09:25:14Z dnsseed thread start
bitcoin | 2022-04-23T09:25:14Z Waiting 300 seconds before querying DNS seeds.
bitcoin | 2022-04-23T09:25:14Z opencon thread start
bitcoin | 2022-04-23T09:25:14Z addcon thread start
bitcoin | 2022-04-23T09:25:14Z msghand thread start
bitcoin | 2022-04-23T09:25:14Z init message: Done loading
bitcoin | 2022-04-23T09:26:49Z Imported mempool transactions from disk: 1778 succeeded, 0 failed, 0 expired, 0 already there, 0 waiting for initial broadcast
bitcoin | 2022-04-23T09:26:49Z loadblk thread exit
bitcoin | 2022-04-23T09:30:14Z Loading addresses from DNS seed seed. bitcoinstats. com
bitcoin | 2022-04-23T09:30:14Z Loading addresses from DNS seed dnsseed. emzy. de
bitcoin | 2022-04-23T09:30:14Z Loading addresses from DNS seed seed. bitcoin. sipa. be
bitcoin | 2022-04-23T09:30:14Z Waiting 300 seconds before querying DNS seeds.
bitcoin | 2022-04-23T09:35:14Z Loading addresses from DNS seed seed. bitcoin. sprovoost. nl
bitcoin | 2022-04-23T09:35:14Z Loading addresses from DNS seed seed. bitcoin. jonasschnelli. ch
bitcoin | 2022-04-23T09:35:14Z Loading addresses from DNS seed dnsseed. bitcoin. dashjr. org
bitcoin | 2022-04-23T09:35:14Z Waiting 300 seconds before querying DNS seeds.
bitcoin | 2022-04-23T09:40:14Z Loading addresses from DNS seed seed. btc. petertodd. org
bitcoin | 2022-04-23T09:40:14Z Loading addresses from DNS seed seed. bitcoin. wiz. biz
bitcoin | 2022-04-23T09:40:14Z Loading addresses from DNS seed dnsseed. bluematt. me
bitcoin | 2022-04-23T09:40:14Z 0 addresses found from DNS seeds
bitcoin | 2022-04-23T09:40:14Z dnsseed thread exit
bitcoin | 2022-04-23T09:52:12Z Potential stale tip detected, will try using extra outbound peer (last tip update: 1904 seconds ago)
bitcoin | 2022-04-23T10:02:42Z Potential stale tip detected, will try using extra outbound peer (last tip update: 2534 seconds ago)
bitcoin | 2022-04-23T10:13:13Z Potential stale tip detected, will try using extra outbound peer (last tip update: 3165 seconds ago)
bitcoin | 2022-04-23T10:23:43Z Potential stale tip detected, will try using extra outbound peer (last tip update: 3795 seconds ago)
