Switching Wi-Fi router?
Anybody have any advice on how to switch to a new Wi-Fi router. My current Wi-Fi system is on the brink. I have a umbrella raspberry pi node system. Just curious how easy or what steps I need to do to switch over. I only have an iPad and not a lab top or tower system. Maybe some advice on which Wi-Fi router to buy. My umbrella raspberry pi system is connected to my current Wi-Fi router and I use the Wi-Fi to manage my node. Thanks in advance. Cheers
So? Do the same steps as you did with the first router.
You should also look into assign a static IP to your node
I have a wi-fi connection, via an ORBI setup. I couldn’t understand the instructions for setting up a static IP address on my desktop. So I have re-flashed the card often, shutdown and reboot the computer and PI many more times and got up to 12.17%, 374k and 65.6GB.
After another bout of shutdown, reflash and reboot, now it’s “synchronizing” but does not show the % or the amount of ledger downloaded and it’s stuck at 67.1GB. Help!
Umbrel logs
0.4.9
Flashed OS version
v0.4.1
Raspberry Pi Model
Revision : d03114
Serial : 1000000083d06601
Firmware
Aug 3 2021 18:14:56
Copyright © 2012 Broadcom
version 40787ee5905644f639a2a0f6e00ae12e517a2211 (clean) (release) (start)
Temperature
temp=59.4’C
Throttling
throttled=0x0
Mem: 7.8G 700M 6.2G 9.0M 933M 7.0G
Swap: 4.1G 0B 4.1G
total: 9.0%
bitcoin: 4.6%
system: 3.9%
tor: 0.4%
electrs: 0.1%
lnd: 0%
Memory monitor logs
2021-12-07 01:49:13 Memory monitor running!
2021-12-07 01:49:26 Memory monitor running!
2021-12-07 01:49:39 Memory monitor running!
2021-12-07 01:49:52 Memory monitor running!
2021-12-07 01:50:05 Memory monitor running!
2021-12-07 01:50:18 Memory monitor running!
2021-12-07 01:50:31 Memory monitor running!
2021-12-07 01:50:44 Memory monitor running!
2021-08-20 16:08:15 Memory monitor running!
2021-12-08 15:54:38 Memory monitor running!
/dev/root 30G 3.0G 25G 11% /
/dev/sda1 916G 63G 807G 8% /home/umbrel/umbrel
Startup service logs
Dec 08 15:54:41 umbrel umbrel startup[1140]: Starting umbrel_app_2_tor_1 …
Dec 08 15:54:41 umbrel umbrel startup[1140]: Starting dashboard …
Dec 08 15:54:41 umbrel umbrel startup[1140]: Starting umbrel_app_3_tor_1 …
Dec 08 15:54:43 umbrel umbrel startup[1140]: Starting dashboard … done
Dec 08 15:54:43 umbrel umbrel startup[1140]: Starting electrs … done
Dec 08 15:54:44 umbrel umbrel startup[1140]: Starting umbrel_app_tor_1 … done
Dec 08 15:54:44 umbrel umbrel startup[1140]: Starting umbrel_app_3_tor_1 … done
Dec 08 15:54:44 umbrel umbrel startup[1140]: Starting tor … done
Dec 08 15:54:44 umbrel umbrel startup[1140]: Starting manager …
Dec 08 15:54:44 umbrel umbrel startup[1140]: Starting umbrel_app_2_tor_1 … done
Dec 08 15:54:46 umbrel umbrel startup[1140]: Starting manager … done
Dec 08 15:54:46 umbrel umbrel startup[1140]: Starting nginx …
Dec 08 15:54:46 umbrel umbrel startup[1140]: Starting lnd …
Dec 08 15:54:47 umbrel umbrel startup[1140]: Starting nginx … done
Dec 08 15:54:47 umbrel umbrel startup[1140]: Starting bitcoin …
Dec 08 15:54:48 umbrel umbrel startup[1140]: Starting lnd … done
Dec 08 15:54:49 umbrel umbrel startup[1140]: Starting bitcoin … done
Dec 08 15:54:49 umbrel umbrel startup[1140]: Starting middleware …
Dec 08 15:54:49 umbrel umbrel startup[1140]: Starting neutrino-switcher …
Dec 08 15:54:51 umbrel umbrel startup[1140]: Starting middleware … done
Dec 08 15:54:52 umbrel umbrel startup[1140]: Starting neutrino-switcher … done
Dec 08 20:09:16 umbrel umbrel startup[1140]: Removing status server iptables entry…
Dec 08 20:09:16 umbrel umbrel startup[1140]: Removed existing iptables entry.
Dec 08 20:09:16 umbrel umbrel startup[1140]: Starting installed apps…
Dec 08 20:09:16 umbrel umbrel startup[1140]: Umbrel is now accessible at
Dec 08 20:09:16 umbrel umbrel startup[1140]: http://umbrel.local
Dec 08 20:09:16 umbrel umbrel startup[1140]: http://10.0.0.3
Dec 08 20:09:16 umbrel systemd[1]: Started Umbrel Startup Service.
Dec 08 20:09:59 umbrel passwd[5203]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
– Logs begin at Wed 2021-12-08 15:54:19 UTC, end at Wed 2021-12-08 20:33:50 UTC. –
Dec 08 15:54:23 umbrel systemd[1]: Starting External Storage Mounter…
Dec 08 15:54:23 umbrel external storage mounter[503]: Running external storage mount script…
Dec 08 15:54:23 umbrel external storage mounter[503]: Found device “ATA CT1000MX500SSD1”
Dec 08 15:54:23 umbrel external storage mounter[503]: Blacklisting USB device IDs against UAS driver…
Dec 08 15:54:23 umbrel external storage mounter[503]: Rebinding USB drivers…
Dec 08 15:54:24 umbrel external storage mounter[503]: Checking USB devices are back…
Dec 08 15:54:24 umbrel external storage mounter[503]: Waiting for USB devices…
Dec 08 15:54:25 umbrel external storage mounter[503]: Waiting for USB devices…
Dec 08 15:54:26 umbrel external storage mounter[503]: Checking if the device is ext4…
Dec 08 15:54:26 umbrel external storage mounter[503]: Yes, it is ext4
Dec 08 15:54:27 umbrel external storage mounter[503]: Checking if device contains an Umbrel install…
Dec 08 15:54:27 umbrel external storage mounter[503]: Yes, it contains an Umbrel install
Dec 08 15:54:27 umbrel external storage mounter[503]: Bind mounting external storage over local Umbrel installation…
Dec 08 15:54:27 umbrel external storage mounter[503]: Bind mounting external storage over local Docker data dir…
Dec 08 15:54:27 umbrel external storage mounter[503]: Bind mounting external storage to /swap
Dec 08 15:54:27 umbrel external storage mounter[503]: Bind mounting SD card root at /sd-card…
Dec 08 15:54:27 umbrel external storage mounter[503]: Checking Umbrel root is now on external storage…
Dec 08 15:54:28 umbrel external storage mounter[503]: Checking /var/lib/docker is now on external storage…
Dec 08 15:54:28 umbrel external storage mounter[503]: Checking /swap is now on external storage…
Dec 08 15:54:28 umbrel external storage mounter[503]: Setting up swapfile
Dec 08 15:54:29 umbrel external storage mounter[503]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 08 15:54:29 umbrel external storage mounter[503]: no label, UUID=8277640f-6878-4559-8e75-ba4870bdf9b3
Dec 08 15:54:29 umbrel external storage mounter[503]: Checking SD Card root is bind mounted at /sd-root…
Dec 08 15:54:29 umbrel external storage mounter[503]: Starting external drive mount monitor…
Dec 08 15:54:29 umbrel external storage mounter[503]: Mount script completed successfully!
Dec 08 15:54:29 umbrel systemd[1]: Started External Storage Mounter.
Dec 08 15:54:38 umbrel systemd[1]: Starting External Storage SDcard Updater…
Dec 08 15:54:38 umbrel external storage updater[1091]: Checking if SD card Umbrel is newer than external storage…
Dec 08 15:54:38 umbrel external storage updater[1091]: No, SD version is not newer, exiting.
Dec 08 15:54:38 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal:
karen is getting triggered!
Got signal:
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
Got signal: change-password
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES STATUS
middleware Up 5 hours
neutrino-switcher Up 5 hours
bitcoin Up 12 seconds
nginx Up 5 hours
lnd Restarting (1) 15 seconds ago
manager Up 5 hours
dashboard Up 5 hours
electrs Up 11 seconds
tor Up 5 hours
umbrel_app_tor_1 Up 5 hours
umbrel_app_2_tor_1 Up 5 hours
umbrel_app_3_tor_1 Up 5 hours
Umbrel logs
Attaching to middleware, manager
manager | at attempt (/app/node_modules/passport/lib/middleware/authenticate.js:180:28)
manager | at JwtStrategy.strategy.fail (/app/node_modules/passport/lib/middleware/authenticate.js:302:9)
manager | at JwtStrategy.authenticate (/app/node_modules/passport-jwt/lib/strategy.js:96:21)
manager | at attempt (/app/node_modules/passport/lib/middleware/authenticate.js:366:16)
manager | at authenticate (/app/node_modules/passport/lib/middleware/authenticate.js:367:7)
manager | at jwt (/app/middlewares/auth.js:146:5)
manager | at Layer.handle [as handle_request] (/app/node_modules/express/lib/router/layer.js:95:5)
manager | at next (/app/node_modules/express/lib/router/route.js:137:13)
manager | ::ffff:10.21.21.2 - - [Wed, 08 Dec 2021 20:34:01 GMT] “GET /v1/system/debug-result HTTP/1.0” 401 13 “-” “OSSProxy 1.3.338.326 (Build 338.326 Win32 en-us)(Oct 1 2020 18:44:57)”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 08 Dec 2021 20:34:03 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
manager |
manager | Invalid JWT
manager | /v1/system/debug-result
manager | NodeError: Invalid JWT
manager | at /app/middlewares/auth.js:137:19
middleware | umbrel-middleware
manager | at allFailed (/app/node_modules/passport/lib/middleware/authenticate.js:107:18)
manager | ::ffff:10.21.21.2 - - [Wed, 08 Dec 2021 20:34:03 GMT] “GET /v1/system/debug-result HTTP/1.0” 401 13 “-” “OSSProxy 1.3.338.326 (Build 338.326 Win32 en-us)(Oct 1 2020 18:44:57)”
manager |
middleware | Unable to list pending channels, waiting to start, RPC services not available
middleware | /v1/lnd/channel
middleware | LndError: Unable to list pending channels
middleware | at /app/services/lnd.js:69:18
middleware | at Object.onReceiveStatus (/app/node_modules/grpc/src/client_interceptors.js:1210:9)
middleware | at InterceptingListener._callNext (/app/node_modules/grpc/src/client_interceptors.js:568:42)
middleware | at InterceptingListener.onReceiveStatus (/app/node_modules/grpc/src/client_interceptors.js:618:8)
middleware | at callback (/app/node_modules/grpc/src/client_interceptors.js:847:24)
middleware | ::ffff:10.21.21.2 - - [Wed, 08 Dec 2021 20:33:44 GMT] “GET /v1/lnd/channel HTTP/1.0” 500 79 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
middleware |
middleware | (node:35) UnhandledPromiseRejectionWarning: LndError: Unable to list channels
middleware | (node:35) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 55)
middleware | Unable to get payments, waiting to start, RPC services not available
middleware | /v1/lnd/lightning/payments
middleware | LndError: Unable to get payments
middleware | ::ffff:10.21.21.2 - - [Wed, 08 Dec 2021 20:33:44 GMT] “GET /v1/lnd/lightning/payments HTTP/1.0” 500 70 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36”
middleware |
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-12-08T20:34:06Z Setting nMinimumChainWork=00000000000000000000000000000000000000001fa4663bbbe19f82de910280
bitcoin | 2021-12-08T20:34:06Z Using the ‘standard’ SHA256 implementation
bitcoin | 2021-12-08T20:34:06Z Default data directory /data/.bitcoin
bitcoin | 2021-12-08T20:34:06Z Using data directory /data/.bitcoin
bitcoin | 2021-12-08T20:34:06Z Config file: /data/.bitcoin/bitcoin.conf
bitcoin | 2021-12-08T20:34:06Z Config file arg: bind=“10.21.21.8”
bitcoin | 2021-12-08T20:34:06Z Config file arg: blockfilterindex=“1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: dbcache=“200”
bitcoin | 2021-12-08T20:34:06Z Config file arg: deprecatedrpc=“addresses”
bitcoin | 2021-12-08T20:34:06Z Config file arg: listen=“1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: maxmempool=“300”
bitcoin | 2021-12-08T20:34:06Z Config file arg: peerblockfilters=“1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: peerbloomfilters=“1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: port=“8333”
bitcoin | 2021-12-08T20:34:06Z Config file arg: proxy=“10.21.21.11:9050”
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcallowip=“10.21.21.1/16”
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcallowip=“127.0.0.1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcauth=****
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcbind=****
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcport=“8332”
bitcoin | 2021-12-08T20:34:06Z Config file arg: rpcworkqueue=“64”
bitcoin | 2021-12-08T20:34:06Z Config file arg: txindex=“1”
bitcoin | 2021-12-08T20:34:06Z Config file arg: zmqpubhashblock=“tcp://0.0.0.0:28334”
bitcoin | 2021-12-08T20:34:06Z Config file arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
bitcoin | 2021-12-08T20:34:06Z Using 16 MiB out of
LND logs
Attaching to lnd
lnd | 2021-12-08 20:32:41.879 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2021-12-08 20:32:41.885 [INF] LTND: Creating local graph and channel state DB instances
lnd | 2021-12-08 20:32:41.932 [INF] CHDB: Checking for schema update: latest_version=24, db_version=24
lnd | 2021-12-08 20:32:41.932 [INF] LTND: Database(s) now open (time_to_open=51.588597ms)!
lnd | 2021-12-08 20:32:43.388 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-12-08 20:32:43.389 [ERR] LTND: Shutting down because error in main method: error creating wallet config: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-12-08 20:32:43.393 [INF] LTND: Shutdown complete
lnd |
lnd | error creating wallet config: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-12-08 20:33:44.560 [INF] LTND: Version: 0.14.1-beta commit=v0.14.1-beta, build=production, logging=default, debuglevel=info
lnd | 2021-12-08 20:33:44.560 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-12-08 20:33:44.562 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd | 2021-12-08 20:33:44.565 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd | 2021-12-08 20:33:44.566 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2021-12-08 20:33:44.566 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2021-12-08 20:33:44.567 [INF] LTND: Creating local graph and channel state DB instances
lnd | 2021-12-08 20:33:44.582 [INF] CHDB: Checking for schema update: latest_version=24, db_version=24
lnd | 2021-12-08 20:33:44.582 [INF] LTND: Database(s) now open (time_to_open=15.97835ms)!
lnd | 2021-12-08 20:33:44.839 [ERR] RPCS: [/lnrpc.Lightning/WalletBalance]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.839 [ERR] RPCS: [/lnrpc.Lightning/GetTransactions]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.872 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.874 [ERR] RPCS: [/lnrpc.Lightning/PendingChannels]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.875 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.877 [ERR] RPCS: [/lnrpc.Lightning/ListInvoices]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:44.940 [ERR] RPCS: [/lnrpc.Lightning/ListPayments]: waiting to start, RPC services not available
lnd | 2021-12-08 20:33:46.100 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-12-08 20:33:46.100 [ERR] LTND: Shutting down because error in main method: error creating wallet config: unable to initialize neutrino backend: unable to create neutrino light client: EOF
lnd | 2021-12-08 20:33:46.115 [INF] LTND: Shutdown complete
lnd |
electrs logs
Attaching to electrs
electrs | [2021-12-08T20:33:56.469Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:33:57.471Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:33:58.473Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:33:59.476Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:00.478Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:01.481Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:02.488Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:03.492Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:04.493Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs | Error: electrs failed
electrs |
electrs | Caused by:
electrs | 0: bitcoind RPC polling failed
electrs | 1: daemon not available
electrs | 2: JSON-RPC error: transport error: Couldn’t connect to host: Connection refused (os error 111)
electrs | Starting electrs 0.9.1 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile("/data/.bitcoin/.cookie"), daemon_rpc_addr: V4(10.21.21.8:8332), daemon_p2p_addr: V4(10.21.21.8:8333), electrum_rpc_addr: V4(0.0.0.0:50001), monitoring_addr: V4(127.0.0.1:4224), wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: Some(200), reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, disable_electrum_rpc: false, server_banner: “Umbrel v0.4.9”, args: [] }
electrs | [2021-12-08T20:34:06.433Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs | [2021-12-08T20:34:06.571Z INFO electrs::db] “/data/db/bitcoin”: 2349 SST files, 0.001890945 GB, 0.000000021 Grows
electrs | [2021-12-08T20:34:06.614Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs |
electrs | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs | 1: No such file or directory (os error 2)
electrs | [2021-12-08T20:34:08.046Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs | [2021-12-08T20:34:08.184Z INFO electrs::db] “/data/db/bitcoin”: 2350 SST files, 0.00189175 GB, 0.000000021 Grows
electrs | [2021-12-08T20:34:08.228Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:09.230Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
electrs | [2021-12-08T20:34:10.232Z INFO electrs::daemon] waiting for RPC warmup: Loading block index…
Tor logs
==== Result ====
Did you figure out how to do this? Can I just change my wifi and password through SSH into my umbrel using my IP address?
