Same result. It’s like the path to the repository has been changed or is being blocked. Is there a patch coming out soon? This 0.5.4 update seems to be the crashing a lot of nodes.
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/debug
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03115
Serial : 10000000f38c7854
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=36.5’C
Throttling
throttled=0x0
Mem: 7.8G 424M 6.1G 8.0M 1.2G 7.3G
Swap: 4.1G 0B 4.1G
total: 5.4%
system: 5.4%
Memory monitor logs
2023-09-24 05:32:20 Memory monitor running!
2023-09-24 16:12:14 Memory monitor running!
2023-09-24 16:29:02 Memory monitor running!
2023-09-24 16:42:42 Memory monitor running!
2023-09-24 16:46:42 Memory monitor running!
2023-09-24 16:47:40 Memory monitor running!
2023-09-29 04:04:14 Memory monitor running!
/dev/root 60G 4.1G 53G 8% /
/dev/sda1 916G 5.4G 864G 1% /home/umbrel/umbrel
Startup service logs
Sep 24 16:47:40 umbrel umbrel startup[980]: ======================================
Sep 24 16:47:40 umbrel umbrel startup[980]: ============= STARTING ===============
Sep 24 16:47:40 umbrel umbrel startup[980]: ============== UMBREL ================
Sep 24 16:47:40 umbrel umbrel startup[980]: Setting environment variables…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting karen…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting status monitors…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting memory monitor…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting backup monitor…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting decoy backup trigger…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting umbreld…
Sep 24 16:47:40 umbrel umbrel startup[980]: Starting Docker services…
Sep 24 16:47:43 umbrel umbrel startup[980]: Creating network “umbrel_main_network” with the default driver
Sep 24 16:47:50 umbrel umbrel startup[980]: Creating dashboard …
Sep 24 16:47:50 umbrel umbrel startup[980]: Creating manager …
Sep 24 16:47:50 umbrel umbrel startup[980]: Creating tor_proxy …
Sep 24 16:47:50 umbrel umbrel startup[980]: Creating auth …
Sep 24 16:48:05 umbrel umbrel startup[980]: Creating tor_proxy … done
Sep 24 16:48:06 umbrel umbrel startup[980]: Creating dashboard … done
Sep 24 16:48:06 umbrel umbrel startup[980]: Creating manager … done
Sep 24 16:48:06 umbrel umbrel startup[980]: Creating nginx …
Sep 24 16:48:06 umbrel umbrel startup[980]: Creating auth … done
Sep 24 16:48:07 umbrel umbrel startup[980]: Creating nginx … done
Sep 24 16:48:07 umbrel umbrel startup[980]: Removing status server iptables entry…
Sep 24 16:48:07 umbrel umbrel startup[980]: Removed existing iptables entry.
Sep 24 16:48:07 umbrel umbrel startup[980]: Starting installed apps…
Sep 24 16:48:07 umbrel umbrel startup[980]: Umbrel is now accessible at
Sep 24 16:48:07 umbrel umbrel startup[980]: http://umbrel.local
Sep 24 16:48:07 umbrel umbrel startup[980]: local ip address
Sep 24 16:48:07 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Sep 24 16:47:23 umbrel external storage mounter[481]: Running external storage mount script…
Sep 24 16:47:23 umbrel external storage mounter[481]: Found device "SABRENT "
Sep 24 16:47:23 umbrel external storage mounter[481]: Blacklisting USB device IDs against UAS driver…
Sep 24 16:47:23 umbrel external storage mounter[481]: Rebinding USB drivers…
Sep 24 16:47:23 umbrel external storage mounter[481]: Checking USB devices are back…
Sep 24 16:47:23 umbrel external storage mounter[481]: Waiting for USB devices…
Sep 24 16:47:24 umbrel external storage mounter[481]: Waiting for USB devices…
Sep 24 16:47:25 umbrel external storage mounter[481]: Waiting for USB devices…
Sep 24 16:47:26 umbrel external storage mounter[481]: Checking if the device is ext4…
Sep 24 16:47:26 umbrel external storage mounter[481]: Yes, it is ext4
Sep 24 16:47:26 umbrel external storage mounter[481]: Checking filesystem for corruption…
Sep 24 16:47:26 umbrel external storage mounter[481]: e2fsck 1.44.5 (15-Dec-2018)
Sep 24 16:47:27 umbrel external storage mounter[481]: umbrel: clean, 81675/61054976 files, 5497001/244190208 blocks
Sep 24 16:47:27 umbrel external storage mounter[481]: Mounting partition…
Sep 24 16:47:27 umbrel external storage mounter[481]: Checking if device contains an Umbrel install…
Sep 24 16:47:27 umbrel external storage mounter[481]: Yes, it contains an Umbrel install
Sep 24 16:47:27 umbrel external storage mounter[481]: Bind mounting external storage over local Umbrel installation…
Sep 24 16:47:27 umbrel external storage mounter[481]: Bind mounting external storage over local Docker data dir…
Sep 24 16:47:27 umbrel external storage mounter[481]: Bind mounting external storage to /swap
Sep 24 16:47:27 umbrel external storage mounter[481]: Bind mounting SD card root at /sd-card…
Sep 24 16:47:27 umbrel external storage mounter[481]: Checking Umbrel root is now on external storage…
Sep 24 16:47:28 umbrel external storage mounter[481]: Checking /var/lib/docker is now on external storage…
Sep 24 16:47:28 umbrel external storage mounter[481]: Checking /swap is now on external storage…
Sep 24 16:47:28 umbrel external storage mounter[481]: Setting up swapfile
Sep 24 16:47:28 umbrel external storage mounter[481]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Sep 24 16:47:28 umbrel external storage mounter[481]: no label, UUID=95aa11c6-f9cd-4885-a993-c428d568cda7
Sep 24 16:47:28 umbrel external storage mounter[481]: Checking SD Card root is bind mounted at /sd-root…
Sep 24 16:47:28 umbrel external storage mounter[481]: Starting external drive mount monitor…
Sep 24 16:47:28 umbrel external storage mounter[481]: Mount script completed successfully!
Sep 24 16:47:28 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Sun 2023-09-24 16:47:17 UTC, end at Fri 2023-09-29 04:06:25 UTC. –
Sep 24 16:47:40 umbrel systemd[1]: Starting External Storage SDcard Updater…
Sep 24 16:47:40 umbrel external storage updater[903]: Checking if SD card Umbrel is newer than external storage…
Sep 24 16:47:40 umbrel external storage updater[903]: No, SD version is not newer, exiting.
Sep 24 16:47:40 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
4291 bytes (4.3 kB, 4.2 KiB) copied, 0.000259273 s, 16.6 MB/s
Creating encrypted tarball…
backup/
backup/.padding
Uploading backup…
100 4957 100 146 100 4811 43 1419 0:00:03 0:00:03 --:–:-- 1462
{“message”:“Successfully uploaded backup 1695957285358.tar.gz.pgp for backup ID 18ab908f13a931739c29db44e3bdeae2a47748eb3b7dd21378db9c12a28251a1”}
====== Backup success =======
Got signal:
karen is getting triggered!
Got signal:
Got signal: app-install-bitcoin
Installing ‘bitcoin’ from: GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how → https://github.com/getumbrel/umbrel-apps#readme
Setting up data dir for app bitcoin…
sending incremental file list
sent 378 bytes received 18 bytes 792.00 bytes/sec
total size is 13,135 speedup is 33.17
Pulling images for app bitcoin…
Pulling i2pd_daemon …
Pulling bitcoind …
Pulling app_proxy …
Pulling server …
Pulling tor …
Pulling bitcoind … pulling from lncm/bitcoind
Pulling tor … error
Pulling i2pd_daemon … error
Pulling server … pulling from getumbrel/umbrel-bit…
Pulling bitcoind … digest: sha256:fad11d4874f1c2dc43…
Pulling bitcoind … status: image is up to date for l…
Pulling bitcoind … done
Pulling app_proxy … pulling from getumbrel/app-proxy
ERROR: for tor Get “https://registry-1.docker.io/v2/getumbrel/tor/manifests/sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a”: Get “https://auth.docker.io/token?scope=repository%3Agetumbrel%2Ftor%3Apull&service=registry.docker.io”: dial tcp [2600:1f18:2148:bc01:a3b0:6734:c617:7c5c]:443: connect: network is unreachable
ERROR: for i2pd_daemon Get “https://registry-1.docker.io/v2/purplei2p/i2pd/manifests/sha256:d154a599793c393cf9c91f8549ba7ece0bb40e5728e1813aa6dd4c210aa606f6”: Get “https://auth.docker.io/token?scope=repository%3Apurplei2p%2Fi2pd%3Apull&service=registry.docker.io”: dial tcp [2600:1f18:2148:bc01:a3b0:6734:c617:7c5c]:443: connect: network is unreachable
ERROR: for server Get “https://registry-1.docker.io/v2/getumbrel/umbrel-bitcoin/manifests/sha256:f23b90e3373eef0c756287e50d4b680481847d2be59ad4a1fcc05f7016fc9e43”: dial tcp [2600:1f18:2148:bc02:cfd8:db68:ea1f:277c]:443: connect: network is unreachable
ERROR: for app_proxy Get “https://registry-1.docker.io/v2/getumbrel/app-proxy/manifests/sha256:130fb1572fa23e740b4b7b97bce2c206ead6b138d321ff152b1ba35ead61e67a”: dial tcp [2600:1f18:2148:bc01:a3b0:6734:c617:7c5c]:443: connect: network is unreachable
Docker containers
NAMES STATUS
nginx Up 2 minutes
manager Up 2 minutes
dashboard Up 2 minutes
tor_proxy Up 2 minutes
auth Up 2 minutes
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:12 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:17 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:22 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/system/is-sd-card-failing HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/system/memory HTTP/1.0” 200 84 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/system/storage HTTP/1.0” 200 88 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/system/temperature HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:26 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
manager | ::ffff:10.21.21.2 - - [Fri, 29 Sep 2023 04:06:27 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/118.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Sep 29 04:04:27.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_proxy | Sep 29 04:04:27.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_proxy | Sep 29 04:04:27.000 [notice] Bootstrapped 67% (loading_descriptors): Loading relay descriptors
tor_proxy | Sep 29 04:04:27.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_proxy | Sep 29 04:04:28.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_proxy | Sep 29 04:04:28.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_proxy | Sep 29 04:04:28.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_proxy | Sep 29 04:04:29.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_proxy | Sep 29 04:04:29.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_proxy | Sep 29 04:04:29.000 [notice] Bootstrapped 100% (done): Done
==== Result ====
==== END =====
