Stuck Rebooting
Noticed one of my wallets wasn’t connecting. As I’ve done before, I went to settings, clicked reboot. this usually only takes about 5 minutes. It’s been stuck for almost an hour. Should I just turn it off and back on, or any suggestions?
Yes, just turn it off and back on – if it doesn’t show the Umbrel login window after the reboot, then you can safely reflash the microSD card, it’ll fix the issue.
Yep. Unplugging and plugging back in worked. Never seen that happen before, but like they say, you learn something new every day. Thanks!
I’m glad my suggestion worked, it happens to everyone – it doesn’t hurt to ask to be sure.
