Stuck on update
Hi there
I was trying to update my umbrel (rapiberry pi) via webbrowser on windows 10 (firefox) and get stuck for 15h.
My raspberry is connected via cable and have 1TB ssd.
After that I have connect to my node via ssh and reboot it. Now I get this message:
I have try the manual update, but it gives-me a exit message:
Some help will be appreciate
Thanks
Here is my Karen.log file:
I have done this:
SSH into node and run:
rm -f ~/umbrel/statuses/update-in-progress && sudo reboot
The node will reboot and all will be back.
Now my node is back again
after a reboot somehow it start to update once again.
now I’m stuck again.
I have tried to re-flash the SD card with the version 0.5.0, but with the same results.
Any help is appreciate.
Thanks
here the debug:
some more logs
OK, I downgrade to older versions.
cd ~/umbrel && sudo ./scripts/update/update --repo getumbrel/umbrel#v0.4.8
it works now
