I keep getting the same log file errors when trying to add Indexers in either Jackett or Prowlarr.
I understand Umbrel doesn’t have an SSL implementation.
I’m unsure if it’s linked, or I simply haven’t completed a setup step.
Jackett log entry…
Jackett.Common.IndexerException: Exception (torrentz2nz): Cannot determine the frame size or a corrupted frame was received.
[v0.21.1323.0] Jackett.Common.IndexerException: Exception (torrentz2nz): Cannot determine the frame size or a corrupted frame was received.
—> System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
—> System.IO.IOException: Cannot determine the frame size or a corrupted frame was received.
at System.Net.Security.SslStream.GetFrameSize(ReadOnlySpan1 buffer) at System.Net.Security.SslStream.ReceiveBlobAsync[TIOAdapter](TIOAdapter adapter) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation1.WaitWithCancellationAsync(CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at FlareSolverrSharp.ClearanceHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken)
at Jackett.Common.Utils.Clients.HttpWebClient2.Run(WebRequest webRequest) in ./Jackett.Common/Utils/Clients/HttpWebClient2.cs:line 178
at Jackett.Common.Utils.Clients.WebClient.GetResultAsync(WebRequest request) in ./Jackett.Common/Utils/Clients/WebClient.cs:line 186
at Jackett.Common.Indexers.BaseWebIndexer.RequestWithCookiesAsync(String url, String cookieOverride, RequestType method, String referer, IEnumerable1 data, Dictionary2 headers, String rawbody, Nullable1 emulateBrowser) in ./Jackett.Common/Indexers/BaseIndexer.cs:line 558 at Jackett.Common.Indexers.CardigannIndexer.PerformQuery(TorznabQuery query) in ./Jackett.Common/Indexers/CardigannIndexer.cs:line 1505 at Jackett.Common.Indexers.BaseIndexer.ResultsForQuery(TorznabQuery query, Boolean isMetaIndexer) in ./Jackett.Common/Indexers/BaseIndexer.cs:line 339 --- End of inner exception stack trace --- at Jackett.Common.Indexers.BaseIndexer.ResultsForQuery(TorznabQuery query, Boolean isMetaIndexer) in ./Jackett.Common/Indexers/BaseIndexer.cs:line 357 at Jackett.Common.Indexers.BaseWebIndexer.ResultsForQuery(TorznabQuery query, Boolean isMetaIndexer) in ./Jackett.Common/Indexers/BaseIndexer.cs:line 733 at Jackett.Common.Services.IndexerManagerService.TestIndexer(String name) in ./Jackett.Common/Services/IndexerManagerService.cs:line 319 at Jackett.Server.Controllers.IndexerApiController.Test() in ./Jackett.Server/Controllers/IndexerApiController.cs:line 132 at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfIActionResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments) at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask1 actionResultValueTask)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Jackett.Server.Middleware.CustomExceptionHandler.Invoke(HttpContext httpContext) in ./Jackett.Server/Middleware/CustomExceptionHandler.cs:line 26
Prowlarr log entry…
2023-12-08 12:12:21.8|Warn|ProwlarrErrorPipeline|Invalid request Validation failed:
– : Unable to connect to indexer, check the log for more details
2023-12-08 12:12:24.1|Info|Cardigann|Adding request: https://yts.mx/api/v2/list_movies.json?query_term=&limit=50&sort_by=date_added&order_by=desc
2023-12-08 12:12:24.2|Warn|Cardigann|Unable to connect to indexer
[v0.4.4.1947] System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
—> System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer.
—> System.Net.Sockets.SocketException (104): Connection reset by peer
— End of inner exception stack trace —
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token)
at System.Net.Security.SslStream.g__InternalFillHandshakeBufferAsync|189_0[TIOAdapter](TIOAdapter adap, ValueTask1 task, Int32 minSize) at System.Net.Security.SslStream.ReceiveBlobAsync[TIOAdapter](TIOAdapter adapter) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request) at System.Threading.Tasks.TaskCompletionSourceWithCancellation1.WaitWithCancellationAsync(CancellationToken cancellationToken)
at System.Net.Http.AuthenticationHelper.SendWithAuthAsync(HttpRequestMessage request, Uri authUri, Boolean async, ICredentials credentials, Boolean preAuthenticate, Boolean isProxyAuth, Boolean doRequestAuth, HttpConnectionPool pool, CancellationToken cancellationToken)
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponseAsync(HttpRequest request, CookieContainer cookies) in D:\a\1\s\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 108
at NzbDrone.Common.Http.HttpClient.ExecuteRequestAsync(HttpRequest request, CookieContainer cookieContainer) in D:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 170
at NzbDrone.Common.Http.HttpClient.ExecuteAsync(HttpRequest request) in D:\a\1\s\src\NzbDrone.Common\Http\HttpClient.cs:line 70
at NzbDrone.Core.Indexers.IndexerHttpClient.ExecuteProxiedAsync(HttpRequest request, ProviderDefinition definition) in D:\a\1\s\src\NzbDrone.Core\Indexers\IndexerHttpClient.cs:line 42
at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchIndexerResponse(IndexerRequest request) in D:\a\1\s\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 375 at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in D:\a\1\s\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 314
at NzbDrone.Core.Indexers.HttpIndexerBase`1.TestConnection() in D:\a\1\s\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 455
2023-12-08 12:12:24.2|Error|Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware|An unhandled exception has occurred while executing the request.
[v0.4.4.1947] FluentValidation.ValidationException: Validation failed:
at Prowlarr.Api.V1.ProviderControllerBase3.VerifyValidationResult(ValidationResult validationResult, Boolean includeWarnings) in D:\a\1\s\src\Prowlarr.Api.V1\ProviderControllerBase.cs:line 209 at Prowlarr.Api.V1.ProviderControllerBase3.Test(TProviderDefinition definition, Boolean includeWarnings) in D:\a\1\s\src\Prowlarr.Api.V1\ProviderControllerBase.cs:line 195
at Prowlarr.Api.V1.ProviderControllerBase`3.UpdateProvider(TProviderResource providerResource) in D:\a\1\s\src\Prowlarr.Api.V1\ProviderControllerBase.cs:line 87
at lambda_method330(Closure , Object , Object )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
— End of stack trace from previous location —
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
at Prowlarr.Http.Middleware.BufferingMiddleware.InvokeAsync(HttpContext context) in D:\a\1\s\src\Prowlarr.Http\Middleware\BufferingMiddleware.cs:line 28
at Prowlarr.Http.Middleware.IfModifiedMiddleware.InvokeAsync(HttpContext context) in D:\a\1\s\src\Prowlarr.Http\Middleware\IfModifiedMiddleware.cs:line 41
at Prowlarr.Http.Middleware.CacheHeaderMiddleware.InvokeAsync(HttpContext context) in D:\a\1\s\src\Prowlarr.Http\Middleware\CacheHeaderMiddleware.cs:line 33
at Prowlarr.Http.Middleware.UrlBaseMiddleware.InvokeAsync(HttpContext context) in D:\a\1\s\src\Prowlarr.Http\Middleware\UrlBaseMiddleware.cs:line 27
at Prowlarr.Http.Middleware.VersionMiddleware.InvokeAsync(HttpContext context) in D:\a\1\s\src\Prowlarr.Http\Middleware\VersionMiddleware.cs:line 28
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware.g__Awaited|6_0(ExceptionHandlerMiddleware middleware, HttpContext context, Task task)
2023-12-08 12:12:24.3|Warn|ProwlarrErrorPipeline|FluentValidation.ValidationException: Validation failed:
2023-12-08 12:12:24.3|Warn|ProwlarrErrorPipeline|Invalid request Validation failed:
