Attempting to run a Bitcoin full node on a Raspberry Pi 4.
I have run the following commands:
ssh -t umbrel@192.168.1.112
Connecting via IP results in the command hanging (no response).
ssh umbrel@umbrel.local
Using umbrel.local results in “ssh: Could not resolve hostname umbrel.local: No such host is known.”
I have also tried ssh on another device (macOS) and both commands just hang.
Ping statistics for 192.168.1.112:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
I can ping the IP and I receive a response meaning the node is connected and reachable.
I had issues with none of my apps starting, updating, or opening. I powered off the node multiple times, tested the connection, took the SD card and SSD out, and tried them again. Nothing worked, and then I seemed to have created another problem as the local web server is no longer reachable.
Please help. Thanks ![]()
