Sparrow Wallet Connection to Umbrel
Hi there,
I’m trying to connect my Umbrel to Sparrow Wallet.
I keep getting errors.
Initially I got an error because Tor was running, so I shut that down and then retried, it managed to do some things and then presented me with this error:
“Could not Connect:
Cannot connect to hidden service”
Any help would be greatly appreciated.
Capture
I got this sorted out.
All you need to do is wait ~12 hours after full sync of your node before you try to connect it to Sparrow.
Hi - I get exact same error… and it is more than 12 hrs since full sync.
But I will give it a day more - then let’s see! Thanks for heads up!
I still get this connection error. It is as if the Umbrels electrum server hasn’t opened the port to receive requests…
Everyone says “wait 12 hours” - but I waited for more than 2 days now… how can I check if the port is open or not? And how to open it, if it’s closed?
I noticed this in bitcoin log:
bitcoin | 2021-05-19T10:46:36Z Socks5() connect to 82.217.119.121:8333 failed: connection refused
Getting same error. Any new tips?
I was able to connect Sparrow wallet again. I think we just needed to wait a little bit after updating the node.
Yeah, it turned out that electrs was reindexing.
