Can't connect Sparrow Wallet with Umbrel
Electrs is permanently stuck on 99% when synchronising, so I’m not sure if this is the problem. I’ve tried these steps, but it hasn’t resolved the issue: https://www.reddit.com/r/getumbrel/comments/ylpzqs/must_try_commands_to_fix_everything_wrong_with/?utm_source=share&utm_medium=web2x&context=3
When I try to set up a private electrum server using my Electrs onion url and hit 'Test Connection" Sparrow returns
Could not connect:
Cannot connect to hidden service
Connection failed: IO Error (Cannot connect to hidden service)
Any thoughts?
Can you also SSH and try this command @bc1?
~/umbrel/scripts/app restart electrs
Let me know if this gets you to 100% sync’d and connected
@usernameisJim thanks! that worked for me.
