Sparrow on node itself or via TOR?
Security wise, is it better to install Sparrow Wallet on the node itself and use localhost or connect via TOR from another machine?
I wouldn’t think it would matter.
Be sure to use a hardware wallet with sparrow
with TOR there is an extra connection or not? when you connect via TOR on your LAN, does it stay within the LAN or is it looped outside my LAN? my gut feeling says, anything you remove in between is better. i really try to understand it.
