I tried to login from local and my I.P…I keep getting this error. I did not change it from before the update.
Im in the bottom right port, closest to the eth cable.
Im just getting a red light on my pi. Not sure where to go from here, I tried to restart a few times, no luck.
Any suggestions??
Hey there. Had the same issue.
This helped: Umbrel Troubleshooting Guide
Hope you back back and running.
Cheers
Ohhh wow…you TOTALLy saved me! I am nervous about my terminal usage…but you gave me the perfect directions, thank you so very much!!
All fixed back up and running!
